Time Period of Timer1
Results 1 to 4 of 4
    Let's see all the code...
    Are you resetting the interrupt flags when you go to process the interrupt itself? They don't reset themselves...
    Mar 2006
    Default Address vs Value
    Hello,
    I think the following code is not doing what you expect.
    Timerset = $292B ' 22 ms with prescale of 1:2 dec 10541
    The above line looks like it is setting the value of a variable.
    movlw LOW(Timerset) ; 1 instruction cycle
    This line takes the address of the variable in ram, it does not use its value.
    addwf TMR1L,F ; 1 instruction cycle
    movlw HIGH(Timerset) ; 1 instruction cycle
    addwfc TMR1H,F ; 1 instruction cycle
    If you never change the timeout value, you could change to something like
    TIMERSET EQU $292B
    and the movlw LOW(TIMERSET) will work.
    If you want to change the timeout value at runtime
    use something like
    movfw TimerSet+1 ; Get the low byte of TimerSet variable
    addwf TMR1L, F
    movfw TimerSet ; Get the high byte of TimerSet variable
    addwfc TMR1H, F
    Keith
    Jan 2007
    Colorado
    Default That was it
    Keith, you hit the nail on the head , thank you. It works. I had all the rest of the code going except the timer. I got it going using The Timerset as a constant, and that did it. I now have a RTTY Teletype.
    I still would like the time to be a variable so I could tune it a bit, but my assembler does not know about movwf. it will assemble movfw, so now to figure that one out....
    I have not programmed assembler for many years. I first learned FAP(fortran assembler program) in 1964.. Just beginning to get good at it, and they made me manager of the department... So back to study and thank you so much
    Jack W0KPH
  1. Interrupt RPM and Taylors Elapsed time on 18F4620
    Last Post: - 3rd February 2010, 16:12
  2. Software PWM using Timer1
    By muqasim in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 11:49
  3. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  4. RC5 decode on a 10F + Question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 11th September 2008, 08:20
  5. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:55
