Time Period of Timer1
Results 1 to 4 of 4
    Jan 2007
    Colorado
    Default Time Period of Timer1
    I am new to the Pic world.
    Here is what I am trying to do. I want to program a RTTY Ham transmitter using a FT18F2620 driving an AH 9834 DDS... But one big problem I had not been able to solve. The length of the timer1 interrupt. I need 22 MS . I am using D. Taylor's code to load the offset value into the timer.. The value computes out to 10541 at 1:2 prescaler... which is $292B
    bcf T1CON,TMR1ON ; Turn off timer
    movlw LOW(Timerset) ; 1 instruction cycle
    addwf TMR1L,F ; 1 instruction cycle
    movlw HIGH(Timerset) ; 1 instruction cycle
    addwfc TMR1H,F ; 1 instruction cycle
    bsf T1CON,TMR1ON ; 1 instruction cycle - Turn TIMER1 back on
    The timer runs at its own speed. I can't seem to change the duration . The settings are shown below I have re-read the spec sheet a good many times.. I have tried settings from 0 to 65000.... It always interrupts at the same time duration...
    Timerset = $292B ' 22 ms with prescale of 1:2 dec 10541
    T1CON = 0 ' ZERO OUT THE TIMER REG
    T1CON.5 = 0 'Prescale 00 = 1:1, 01 = 1:2
    T1CON.4 = 1 ' 10 = 1:4 , 11 == 1:8
    T1CON.0 = 0 'timer on = 1 timer off = 0
    TMR1H = $29 'Timer1 set to 22ms
    TMR1L = $2B 'Timer1 set to 22ms
    RCON.7 = 1 'Enable priority levels on interrupts (IPEN)
    TMR1IE VAR PIE1.0 'Enabel timer interrupt. (TMR1IE0)
    TMR1IF VAR PIR1.0 'interrut flag bit (TMR1IF)
    TMR1IE = 1 'enable timer
    IPR1.0 = 1 'Timer1 interrupt priority high (TMR1IP)
    PIE1.0 = 1 'Timer1 interrupt enable (TMR1IE)
    I have a second interrupt handler for the keyboard to load an input buffer. That appears to be working well... I set it at low priority and the timer one to high priority.
    I hope someone can tell me where I have gone wrong...I just can't change the time between interrupt. the timer has selected some value, and won't change... HELP!!!
    Jack W0KPH
    My Thanks to Joe Rocci for the hardward....
    Let's see all the code...
    Are you resetting the interrupt flags when you go to process the interrupt itself? They don't reset themselves...
    Mar 2006
    Default Address vs Value
    Hello,
    I think the following code is not doing what you expect.
    The above line looks like it is setting the value of a variable.
    This line takes the address of the variable in ram, it does not use its value.
    If you never change the timeout value, you could change to something like
    TIMERSET EQU $292B
    and the movlw LOW(TIMERSET) will work.
    If you want to change the timeout value at runtime
    use something like
    movfw TimerSet+1 ; Get the low byte of TimerSet variable
    addwf TMR1L, F
    movfw TimerSet ; Get the high byte of TimerSet variable
    addwfc TMR1H, F
    Keith
    Jan 2007
    Colorado
    Default That was it
    Keith, you hit the nail on the head , thank you. It works. I had all the rest of the code going except the timer. I got it going using The Timerset as a constant, and that did it. I now have a RTTY Teletype.
    I still would like the time to be a variable so I could tune it a bit, but my assembler does not know about movwf. it will assemble movfw, so now to figure that one out....
    I have not programmed assembler for many years. I first learned FAP(fortran assembler program) in 1964.. Just beginning to get good at it, and they made me manager of the department... So back to study and thank you so much
    Jack W0KPH
  1. Interrupt RPM and Taylors Elapsed time on 18F4620
    Last Post: - 3rd February 2010, 16:12
  2. Software PWM using Timer1
    By muqasim in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 11:49
  3. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  4. RC5 decode on a 10F + Question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 11th September 2008, 08:20
  5. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:55
