New user with PAUSE command problem
Results 1 to 7 of 7
    Dec 2003
    Wichita KS
    Hello Howard,
    Howard>>I know I must be doing something wrong here ... but for the life of can't figure what. Any help or ideas would be greatly appreciated ....<<
    The pause command works great... If you can give us a water down code that shows where the pause does *not* work, maybe we can take a look at it....
    Have you tried Pauseus or slower Pause command to verify?
    Like Pauseus 1? then Pauseus 10 etc?
    I thought I ran into something like this with the 688, until I found out the speed was set to the lowest of 34khz? And my program crawled....while I thought it was dead.
    And, just to through out a few other things...Are you sure the pin you are checking is set as a output pin? Are you sure the pin you are using *IS* a i/o pin?
    Are you reloading a a HEX file, instead of recompiling it and reloading it? Nothing like having a working hex file, and the code that is in the window does not match the Hex file <g>.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Replies: 11
    Last Post: - 12th July 2008, 03:36
  4. Fade out LEDs question
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2008, 11:50
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 04:46
