1st problem - A/D inputs on a PIC don't work with negative voltages. See Post #4.
Do you mean you want to output, on A.1, a serial output representation of the analog input on A.0?Its frequency is 1khz. So, it varies between (0~5) volts. I want a digital output coming from PORTA.1
That's good because I don't see anything in your program that says to change the output on PortA.1 other than it's initial setup.But however, so far I get 5V(DC) from PORTA.1
And again, I don't see any serial output commands.By the way, I use 10 bit ADC and the converted digital values I want to get serially every time when the conversion is over.
And again, how do you plan to see this output? Serial output? LCD? There aren't any in the program.I used ADCIN 0,W0 which reads the values from PORTA.0 and writes to W0. After that, if you look at the code you can see that I am trying to get those values with delay(PAUSEUS).
You're kidding me right? Section 21 of the 18F2455 has no information in it that you can use?I am using 18F2455 and could not find much relating A/D Conversion with it.
You've got a working ADC, what you need to do is to get it to work FOR you. I think what you need to do is play around with the PIC and PBP first. Get an LCD working, get a pushbutton or something working with it...then, hook up a POT across an A/D input pin, then display the value of the POT, doesn't have to be resistance, doesn't have to be voltage, doesn't have to be anything in particular, just display a number that corresponds with the position of the POT as you turn it. Then when you get that working, you can easily work on reading a sine wave.I need working ADC.
And besides, even though the A/D on a '2455 is rated for 100ksps and the PIC can run at 48Mhz, you won't be able to get any useful DSP out it. Not enough horsepower under the hood.
