A/D conversion problem with 18F2455
Results 1 to 14 of 14
    Mar 2007
    Bursa, Turkey
    Angry A/D conversion problem with 18F2455
    Hi everybody. I am now working on 18F2455 because of its USB feature. But I got some troubles with converting.I use 4MHz crystal/resonator. I apply a sinusoidal signal with the amplitude 2,5 or 5 volts and a frequency 2kHz from function generator to PORTA.0. And want an output from PORTA.1. But it behaves strange. The negative parts of this sinusoidal is cut off. It only receives the positive parts. I monitored this event on the scobe. And guess what I got as an output. It is 5V DC. It doesn't change. Today I will try it one more time. Does anyone have any suggestions?
    What am I doing wrong?
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by abdy37 View Post
    You need to offset it. For example, if peak to peak is 5V then you need to reference the center to 2.5V. This is effectively your 0V rail when compared to actual AC. AC isn't AC unless it swings below the 0V rail.
    Mar 2007
    Bursa, Turkey
    Exclamation
    Hi T.Jackson. I will try it out tomorrow. I think it is caused by configuring the VREF+ and VREF-. I configured them as VREF+=Vdd and VREF-=Vss. So I think this why the negative sinusoidals are truncated. But in spite of this I think the A/D module must work. I don't have a chance to change the offset voltage to 2,5 volts as you offered. But I think can figure this out with VREF+=AN2 and VREF-=AN3 by pulling AN2 to +2,5 volt and AN3 to -2,5 volt.
    Here is the code I used:
    W0 VAR WORD
    TRISA.0 = 1 ' Set pin 0 of PORTA an input
    TRISA.1 = 0 ' Set pin 1 of PORTA an output
    PORTA.1 = 0 ' Clear pin 1 of PORTA
    ADCON0 = %00000001 ' Configuring Analog Channel Select bits, A/D
    ' Conversion Status bit, A/D On bit
    ADCON1 = %00001110 ' Configuring Voltage Reference Configuration bits,
    ' A/D Port Configuration Control bits
    ADCON2 = %10010000 ' Configuring A/D Result Format Select bit (Right justified ),
    ' A/D Acquisition Time Select bits (4 TAD), A/D Conversion
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 1
    DEFINE ADC_SAMPLEUS 11
    Conversion:
    ADCON0.1 = 1 ' Set GO/(DONE)' bit. Wait the Automatic Acquisition Time and Start Conversion
    PAUSEUS 50
    IF ADCON0.1 = 0 THEN ADC_BIT_RECEIVING
    IF ADCON0.1 = 1 THEN Conversion
    ADC_BIT_RECEIVING:
    ADCIN 0,W0
    W0.0 = PORTA.1
    PAUSEUS 10
    W0.1 = PORTA.1
    PAUSEUS 10
    W0.2 = PORTA.1
    PAUSEUS 10
    W0.3 = PORTA.1
    PAUSEUS 10
    W0.4 = PORTA.1
    PAUSEUS 10
    W0.5 = PORTA.1
    PAUSEUS 10
    W0.6 = PORTA.1
    PAUSEUS 10
    W0.7 = PORTA.1
    PAUSEUS 10
    W0.8 = PORTA.1
    PAUSEUS 10
    W0.9 = PORTA.1
    Don't worry be happy....
    Good luck with that AN3 theory and hopefully you've got a couple of extra 18F2455's laying around.
    Reference the 18F2455 datasheet, Section 28.0 and Table 28-28, Parameter A22.
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Suggest some good reading material on OPAMPS - Operational Amplifiers. You need to vertically shift up that sine wave so that 0v is actually 2.5v
    w0 var word:trisa.0=1:trisa.1=0:porta.1=0:adcon0=1:adcon1=14:adcon2=$90
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 1
    Conversion:
    ADCON0.1 = 1:PAUSEUS 50 :IF ADCON0.1 = 0 THEN ADC_BIT_RECEIVING
    ADC_BIT_RECEIVING:
    adcin 0,w0:w0.0=porta.1:pausus 10:w0.1=porta.1:pausus 10:w0.2=porta.1:pausus 10
    w0.3=porta.1:pausus 10:w0.4=porta.1:pausus 10:wo.5=porta.1:pausus 10
    w0.6=porta.1:pausus 10:w0.7=porta.1:pausus 10:w0.8=porta.1:pauseus 10
    w0.9=porta.1
    What is this program supposed to do anyways?
    Might help if we saw the whole thing...
    Mar 2007
    Bursa, Turkey
    Question No subject
    Hi Skimask. Thank you for concerning with my problem. Now I am working on a little project or the beginning of a big project. I will explain it shortly.
    I am applying a sinusoidal signal with the offset voltage of 2,5 volts and an amplitude of 5 volts to PORTA.0 . Its frequency is 1khz. So, it varies between (0~5) volts. I want a digital output coming from PORTA.1 . But however, so far
    I get 5V(DC) from PORTA.1 . By the way, I use 10 bit ADC and the converted
    digital values I want to get serially every time when the conversion is over.
    The detail is as follows: When the GO/DONE bit is set, the ADC starts. It gathers
    the 10 bit sampled value and writes it into ADRESH(highest 2 bits) and ADRESL(least 8 bits). I did not use it. I used ADCIN 0,W0 which reads the values
    from PORTA.0 and writes to W0. After that, if you look at the code you can see that I am trying to get those values with delay(PAUSEUS). I am using 18F2455
    and could not find much relating A/D Conversion with it. Maybe you have some suggestions. Because you know it is nothing but the beginnig of the project
    and you can not come over the problem. It makes me really crazy. I need working ADC.
    1st problem - A/D inputs on a PIC don't work with negative voltages. See Post #4.
    Do you mean you want to output, on A.1, a serial output representation of the analog input on A.0?
    But however, so far I get 5V(DC) from PORTA.1
    That's good because I don't see anything in your program that says to change the output on PortA.1 other than it's initial setup.
    By the way, I use 10 bit ADC and the converted digital values I want to get serially every time when the conversion is over.
    And again, I don't see any serial output commands.
    I used ADCIN 0,W0 which reads the values from PORTA.0 and writes to W0. After that, if you look at the code you can see that I am trying to get those values with delay(PAUSEUS).
    And again, how do you plan to see this output? Serial output? LCD? There aren't any in the program.
    I am using 18F2455 and could not find much relating A/D Conversion with it.
    You're kidding me right? Section 21 of the 18F2455 has no information in it that you can use?
    I need working ADC.
    You've got a working ADC, what you need to do is to get it to work FOR you. I think what you need to do is play around with the PIC and PBP first. Get an LCD working, get a pushbutton or something working with it...then, hook up a POT across an A/D input pin, then display the value of the POT, doesn't have to be resistance, doesn't have to be voltage, doesn't have to be anything in particular, just display a number that corresponds with the position of the POT as you turn it. Then when you get that working, you can easily work on reading a sine wave.
    And besides, even though the A/D on a '2455 is rated for 100ksps and the PIC can run at 48Mhz, you won't be able to get any useful DSP out it. Not enough horsepower under the hood.
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 17:26
  3. A/D conversion problem on 18F4431
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 00:03
  4. A/D conversion problem with pic16F88
    By Tapio Linkosalo in forum mel PIC BASIC Pro
    Last Post: - 18th August 2006, 12:42
  5. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 19:57
