Code:Public Sub CPU_Makes_Move() '----------------------------------------------------------------------------- '*Here we check for 2 or more of the player's chr on the same row or col, 'the odds that we generate determine as to if we apply the move. '----------------------------------------------------------------------------- '// Dim Apply_Move As Boolean 'Allow CPU to apply calculated move if set true Dim i As Long 'General working var Dim j As Long '"" Dim CPU_Odds As Long 'Random odds based on difficulty setting '(to apply or not to apply the calulated move) CPU_Moved = False '// For i = 0 To (Rnd * 100) + 1 CPU_Odds = (Rnd * 100) 'Rnd num of samples (really scramble it) Next '// 'chance % that CPU will make calculated move Select Case Game_Difficulty Case 0 'Easy, 60% If CPU_Odds <= 60 Then Apply_Move = True Case 1 'Norm, 80% If CPU_Odds <= 80 Then Apply_Move = True Case 2 'hard, 95% If CPU_Odds <= 95 Then Apply_Move = True End Select '// If Apply_Move Then 'Flag set? '// 'Is there a winning possibility in the next move for CPU? Call Perform_Calculated_Move(1) '// 'Lets analyze player's game play, something to block? If Not CPU_Moved Then Call Perform_Calculated_Move(0) End If '// '----------------------------------------------------------------------------- '(Nothing to analyze, nothing to win nor block) 'Pick middle if empty or decide on corner to pick (depending on player's moves) '----------------------------------------------------------------------------- If Not CPU_Moved Then If Grid_Set(1, 1) = 0 Then 'Middle CPU_Moved = True Grid_Set(1, 1) = Players_CHR(Players_Turn) ElseIf Grid_Set(2, 2) = 0 Then 'Bottom right? If Grid_Set(1, 2) = Players_CHR(0) Or Grid_Set(2, 1) = Players_CHR(0) Then CPU_Moved = True Grid_Set(2, 2) = Players_CHR(Players_Turn) End If ElseIf Grid_Set(0, 0) = 0 Then 'Top left? If Grid_Set(0, 2) <> Players_CHR(0) Then CPU_Moved = True Grid_Set(0, 0) = Players_CHR(Players_Turn) End If ElseIf Grid_Set(0, 2) = 0 Then 'Top right? If Grid_Set(0, 0) <> Players_CHR(0) Then CPU_Moved = True Grid_Set(0, 2) = Players_CHR(Players_Turn) End If ElseIf Grid_Set(2, 0) = 0 Then 'Bottom left? CPU_Moved = True Grid_Set(2, 0) = Players_CHR(Players_Turn) End If End If '// '----------------------------------------------------------------------------- 'Look for row / col with CPU's prior moves, then check for empty 'col or row, if that fails look for one of player's prior moves. '----------------------------------------------------------------------------- '// For j = 1 To 0 Step -1 If Not CPU_Moved Then For i = 0 To 2 If Grid_Set(0, i) = Players_CHR(j) And Grid_Set(2, i) = 0 And Grid_Set(1, i) = 0 Then Grid_Set(1, i) = Players_CHR(Players_Turn) CPU_Moved = True Exit For ElseIf Grid_Set(1, i) = Players_CHR(j) And Grid_Set(2, i) = 0 And Grid_Set(0, i) = 0 Then Grid_Set(0, i) = Players_CHR(Players_Turn) CPU_Moved = True Exit For ElseIf Grid_Set(2, i) = Players_CHR(j) And Grid_Set(1, i) = 0 And Grid_Set(0, i) = 0 Then Grid_Set(0, i) = Players_CHR(Players_Turn) CPU_Moved = True Exit For End If Next End If '// 'Row If Not CPU_Moved Then For i = 0 To 2 If Grid_Set(i, 0) = Players_CHR(j) And Grid_Set(i, 2) = 0 And Grid_Set(i, 1) = 0 Then Grid_Set(i, 1) = Players_CHR(Players_Turn) CPU_Moved = True Exit For ElseIf Grid_Set(i, 1) = Players_CHR(j) And Grid_Set(i, 2) = 0 And Grid_Set(i, 0) = 0 Then Grid_Set(i, 0) = Players_CHR(Players_Turn) CPU_Moved = True Exit For ElseIf Grid_Set(i, 2) = Players_CHR(j) And Grid_Set(i, 1) = 0 And Grid_Set(i, 0) = 0 Then Grid_Set(i, 0) = Players_CHR(Players_Turn) CPU_Moved = True Exit For End If Next End If '// 'No prior CPU moves?, find empty col If Not CPU_Moved Then For i = 0 To 2 If Grid_Set(0, i) = 0 And Grid_Set(2, i) = 0 And Grid_Set(1, i) = 0 Then Grid_Set(0, i) = Players_CHR(Players_Turn) CPU_Moved = True Exit For End If Next End If '// 'No empty col?, find row If Not CPU_Moved Then For i = 0 To 2 If Grid_Set(i, 0) = 0 And Grid_Set(i, 2) = 0 And Grid_Set(i, 1) = 0 Then Grid_Set(i, 0) = Players_CHR(Players_Turn) CPU_Moved = True Exit For End If Next End If Next '// Else 'The odds are on the players side, make move by chance '// 'No brainer move', (go fetch any rnd pos) Call Find_Random_Spot End If '// Players_Turn = Players_Turn + 1 'Player makes next turn Players_Turn = Players_Turn Mod 2 'Limit val to 1, player's take successive turns Move_Count = Move_Count + 1 'Keep track of moves, max of 9 Call Scrn_Render 'Render graphics Call Check_For_Win 'Check for wining line End Sub
