Quote Originally Posted by sougata View Post
Excuse me if I am quoting something already mentioned by somebody. I have quickly browsed the thread a may have skipped something. Its sunday and I am back after a long tour. So I am worried about the "Wife" bug to be active any moment!!
If you sample the audio at 8Khz and continuosly throw the sample out through Hardware PWM you would actually be reducing the bandwidth of the input audio. Sort of a low-pass filter. Couple that with dirty (cheap) filtering and the free quantitizing noise. This may be the sound you are actually looking for.
You can have a routine detecting when the ADC is receiving no/low signals. Treat them as end of audio and thus trigger your sound fx routine- handsfree.
Needs some ASM stuff to utilize the conversion and/or acquisition time to update the hardware PWM.
Just a thought.
Great suggestions. I was thinking about using a digital pot to bias the amplifier...maybe go from a normal bias to overbias to get the distortion... Dunno if that will work as planned or if it's even a good idea but I am going to play around with it. I'm not quite up to speed on sampling the audio and using PWM to distort it but it sounds doable. Working on trying to find info on SPI now... Seems the manuals don't cover SPI (or I couldn't find anything in the manual about SPI)... I found some stuff in a few forum on the web. I thought it was a standard command but I can't find any of the includes or Defines listed anywhere in the book... Not even in the Proton Plus manual... Hmmmm
