PIC Audio
Results 1 to 29 of 29
Thread: PIC Audio
    Apr 2006
    New Hampshire USA
    Smile VOX circuits
    Hey Dave,
    That helmet looks great! Very impressive work.
    Good ideas about the MP3s and audio effects.
    If you have time:
    peterdeco1 had a good idea about a recorder playback chip.
    Even one like in a greeting card.
    It does not have to have loud audio, just tap it into the same amplifier for your voice.
    Alfred had some good ideas too, may need a little more power than a LM386. But there are other audio amplifier ICs that might be as simple to use.
    Ross is right about all the sound effects available in MP3 format. It would be handy to just tap into a cheap one and feed the low level (headphone) audio into you voice amp.
    He is right about “Just at the right moment... POW! BAM! BLING! Cut them right in half!” too!
    Can someone try the white noise output of a PIC and let us know if it sounds like radio static “rush” (before squelch mutes it). Maybe post a sound clip?
    Have you looked for any voice operate circuits (VOX)? Here is one example schematic. I like the voltage doubler part.
    http://www.electronickits.com/kit/co.../elec/k126.pdf
    You would not need all the amplifiers / comparators and relay.
    Your amplifier produces the level and the PIC senses voice voltage and switches your effects....
    Great ideas guys, who else?
    -Adam-
    New Hampshire
    Talking
    It may be a little late to point this out but...
    STARWARS ISN'T REAL!...
    It's only a movie.
    Somebody catch him!
    I love wierd people! :-)
    The helmet looks awsome!
    Ross
    Never enough knowledge to be called intelligent but just enough knowledge to be considered dangerous!
    I like that! :-)
    Jun 2006
    Well, I've been looking at Audio amps... The LM383 would have been perfect but it's obsolete. There is a replacement for it though and I found a few others that I like. Almost finished with my armor so I'll start working on the PIC circuit as soon as I get finished with that... And yes, I know Star Wars isn't real
    BUT neither were microwaves and color TV not so long ago... he he
    Have a great evening!
    Jun 2006
    Ok, done with my armor...now on to the audio... I've been playing with the PIC but most of the noise that I can get to come out of it are too "digital sounding"...when using the SOUND command. Reading on the site for the original board I found that the board has 5 different modes as well... One that adjusts the amount of distortion that your voice changes from "Normal" to "Distorted" 1-5 depending on where you set the level. You can also upload wav files to the thing using his software and a computer... Delays from when you finish talking to when the static burst comes out, turning the static sounds on and off...Geez!!
    My questions:
    1. How do you adjust the real time audio distortion if the PIC isn't sampling the audio or do you think it is?
    2. Do you think it is using the 1 bit audio, I.e. the Roman Black 1 bit wav file audio?
    3. Do you think it is using a pre-recorded wav file for the static or generating it using the PIC?
    I'm kinda lost here...None of the white noises that I get from the PIC sound anywhere near what I hear on his site..and there is a click before the rush of white noise... the simulated button release of the radio.
    I've found examples of MMC uses, ISD voice recorder uses and a couple other instances where PICs are being used with other devices to produce audio but I can't really settle on which would be best.
    -Dave
    Feb 2005
    Kolkata-India
    Default It may be possible
    Excuse me if I am quoting something already mentioned by somebody. I have quickly browsed the thread a may have skipped something. Its sunday and I am back after a long tour. So I am worried about the "Wife" bug to be active any moment!!
    If you sample the audio at 8Khz and continuosly throw the sample out through Hardware PWM you would actually be reducing the bandwidth of the input audio. Sort of a low-pass filter. Couple that with dirty (cheap) filtering and the free quantitizing noise. This may be the sound you are actually looking for.
    You can have a routine detecting when the ADC is receiving no/low signals. Treat them as end of audio and thus trigger your sound fx routine- handsfree.
    Needs some ASM stuff to utilize the conversion and/or acquisition time to update the hardware PWM.
    Just a thought.
    Sougata
    Jun 2006
    Quote Originally Posted by sougata View Post
    Just a thought.
    Great suggestions. I was thinking about using a digital pot to bias the amplifier...maybe go from a normal bias to overbias to get the distortion... Dunno if that will work as planned or if it's even a good idea but I am going to play around with it. I'm not quite up to speed on sampling the audio and using PWM to distort it but it sounds doable. Working on trying to find info on SPI now... Seems the manuals don't cover SPI (or I couldn't find anything in the manual about SPI)... I found some stuff in a few forum on the web. I thought it was a standard command but I can't find any of the includes or Defines listed anywhere in the book... Not even in the Proton Plus manual... Hmmmm
    Quote Originally Posted by toofastdave
    See M25P32 PIC Audio **warning, other compiler**
    Includes hardware SPI routines.
    Norm
  1. Replies: 33
    Last Post: - 8th September 2010, 11:28
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  3. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 20:42
  4. Audio Encoding and playback in a PIC
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 24th March 2005, 08:56
