OBD-2 Question
Results 1 to 10 of 10
Thread: OBD-2 Question
    Jun 2005
    Wisconsin
    I have a lot of experience with OBDII, and I agree with skimask. Have fun!
    Mar 2007
    ok! i'm about to fry my ECU
    Just Joking, i hope
    Thank you for your answers!
    Luca
    Quote Originally Posted by oslinux View Post
    Just Joking, i hope
    Luca
    Just curious...
    Are you using J1962 cable/connector or did you tap into the wiring itself?
    I did it both ways; one car I clipped the wiring behind the connector and plugged in a standard DB9 connector, another one I went with a USB connector. Someday I'll decide on one method...
    Mar 2007
    i used the cable, then the DB9 connector, the news are:
    It works!
    and well too!
    Now i'm building the pic circuit, but i found it pretty easy to do, i'm planning to use the usb port of the pic (18F4550) to communicate with a pc (Using a software made by me),
    Now i've just two questions:
    1. where i can find codes to communicate with the car and read the sensors?
    2. what software do you suggest to use with the pc connected directly to the serial port? (FreeWare is good, Open Source is better!)
    Thank you!
    Luca
    Jun 2005
    Wisconsin
    Technically you would need the SAE standard for the codes. However there are a number of websites that will give you the basic OBDII commands.
    As far as software, go to scantool.net and use their opensource software. If you look through their code you will find most of the OBDII commands.
    1 - www.google.com that was my prime source
    2 - self designed PCB, PIC driven, buttons, LCD, etc..., no PC required but USB downloading from datalog memory in the works...
    Mar 2007
    I'm building too a controller with a pic 18F4550, LCD 4*20 White on Black, buttons to show RPM/Coolant Temp/others and an eeprom, to test it i've coded a pic16f84 to emulate the ELM, it's cool
    in my car (Ford KA) i don't even have the RPM counter, so this will be somewhat useful for the driver.
    for the pids, i found them in wikipedia, but they says that there are more modes above #9, from the vehicle manufactures, it's possible to get the additional pids for ford in the net?
    Luca
    Luca
    The big question is 'is it possible to get all the PIDs for all the vehicles out there without paying an arm and a leg'?
    With the new CAN bus out there, you can control anything thru it apparently.
  1. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  2. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  3. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. Microcontroller with 2 way paging application problem
