LED "capacitance" won't get lower
Results 1 to 17 of 17
    Hello,
    I've been reading some threads about the LED's capacity feature and that they can be used as "sensors".
    Now, I made a short program where I involve 3 LEDs to be discharged and measured in time like this:
    The shema is simple: one port connected to all Anodes (through a 330 ohms resistor) and three ports connected each to one Kathode. I use a 16F88 @ 20MHz.....etc....etc....etc....
    Check my webpage, www.srt.com/~jdgrotte, click on LED touch sensor.
    I did basically the same thing awhile back, used 8 LEDs, NO resistors, standard parallel LCD, and an 18F4620 @ 40Mhz.
    Most of the code is posted on the page itself. Should work with a 16F88 at 20Mhz, not sure, never tried.
    Check the video to see it in action (it's a crappy video, I've been meaning to update, never got around to it).
    This is actually my 18F4620 code:
    looper var byte
    anode var porta.1              'common anode of all IR LEDs
    t1 var portc.5 : t2 var portc.4 : t3 var portc.1 : t4 var portc.0 : t5 var porte.2 : t6 var porte.1 : t7 var porta.4 'all IR LEDs cathodes pins
    touchval var word[7] : touchmin var word[7] : touchmax var word[7] : touchrange var word[7] : touchpos var word[7] : touchaverage var word[7]
    touchmidpoint var word[7] : maxval var byte : maxtemp var word
    skipsubs: 'generic setup I use for all my programs, YMMV
    flags=0 : pause 1000 : intcon=0 : intcon.7=1 : intcon.6=1 : intcon.5=1 : intcon2=0 : intcon2.2=1 : intco3=0 : pir1=0 : pir2=0 : pie1=0 : pie1.5=1 : pie1.4=1
    pie2=0 : t0con=0 : t0con.7=1 : t0con.6=1 : t0con=t0con+2 : t1con=0 : t2con=0 : t3con=0 : ccp1con=0 : ccp2con=0 : pwm1con=0 : eccp1as=0 : sspstat=0
    sspcon1=0 : sspcon2=0 : txsta=0 : txsta.6=0 : txsta.5=1 : txsta.4=0 : txsta.2=1 : rcsta=0 : rcsta.7=1 : rcsta.6=0 : rcsta.4=1 : baudcon=0 : baudcon.3=1
    spbrgh=4 : spbrg=16 : adcon0=0 : adcon1=$f : adcon2=$ff : cmcon=7 : cvrcon=0 : hlvdcon=0 : trisa=0 : porta=0 : trisb=0 : portb=0 : trisc=0 : portc=0 : trisd=0
    portd=0 : trise=0 : porte=0 : input switch1 : input switch2 : output led1 : led1=1 : led1=0 : pause 200 : led1=1 : pause 200 : led1=0 : pause 200 : led1=1
    pause 200 : led1=0 : pause 200 : led1=1 : pause 200 : led1=0 : pause 200 : led1=1 : pause 200 : led1=0 : pause 200 : lcdout $fe,1 : switchignorecount=0
    menu=1 : switchdelay=1000 : output serialdataoutputpin : input serialdatainputpin : touchmin = 65000 : touchmax = 100
    loop2:
    led1 = counter.0
    for looper = 1 to 7 'light an LED, even though you can't see it
        output anode : anode=1 : input t1 : t1=0 : input t2 : t2=0 : input t3 : t3=0 : input t4 : t4=0 : input t5 : t5=0 : input t6 : t6=0 : input t7 : t7=0
        select case looper
            case 1
                output t1 : t1 = 0
            case 2
                output t2 : t2 = 0
            case 3
                output t3 : t3 = 0
            case 4
                output t4 : t4 = 0
            case 5
                output t5 : t5 = 0
            case 6
                output t6 : t6 = 0
            case 7
                output t7 : t7 = 0
        end select
        pause 1 : anode = 0
        select case looper 'reverse bias that same LED
            case 1
                output t1 : t1 = 1
            case 2
                output t2 : t2 = 1
            case 3
                output t3 : t3 = 1
            case 4
                output t4 : t4 = 1
            case 5
                output t5 : t5 = 1
            case 6
                output t6 : t6 = 1
            case 7
                output t7 : t7 = 1
        end select
        pause 1
        select case looper 'switch that LED to an input to read it
            case 1
                input t1
            case 2
                input t2
            case 3
                input t3
            case 4
                input t4
            case 5
                input t5
            case 6
                input t6
            case 7
                input t7
        end select
    loop3a:
        'run a counter in a tight loop (loop3a) and keep checking and waiting for the particular LED input to drop from
        'a logic 1 to a logic 0 because the voltage sitting on the LED due to the internal capacitance drops 'slowly'
        touchval[ looper ] = touchval[ looper ] + 1 : if touchval[ looper ] > 65000 then goto kickoutloop3a
        'if we wait too long or the pin is stuck, we'll never get out of the loop
        select case looper
            case 1
                if t1 = 1 then goto loop3a
            case 2
                if t2 = 1 then goto loop3a
            case 3
                if t3 = 1 then goto loop3a
            case 4
                if t4 = 1 then goto loop3a
            case 5
                if t5 = 1 then goto loop3a
            case 6
                if t6 = 1 then goto loop3a
            case 7
                if t7 = 1 then goto loop3a
        end select
    kickoutloop3a:
        counter = counter + 1 'just a counter to show a 'heartbeat'
    next looper
    maxval = 0 : maxtemp = 0 'maxval keeps track of which led had the lowest value, maxtemp keeps track of the lowest value
    for looper = 1 to 7 'check al 7 LEDs to find the lowest one
        if touchval[ looper ] > maxtemp then
            maxtemp = touchval[ looper ] : maxval = looper
    next looper
    'clear out the line, then display the number of the darkest LED
    lcdout $fe , $80 , " " : lcdout $fe , $80 + ( 7 - maxval ) , DEC1 ( 7 - maxval ) : lcdout $fe , $c0 , " " : lcdout $fe , $c0 + ( 7 - maxval ) , $ff
    for looper = 1 to 7 : touchval[ looper ] = 0 : next looper
    goto loop2
    SWITZERLAND (french speaking)
    Wink already done
    Hi skimask,
    I've read lots of threads and went already on your site (btw: thank you) and many others about this topic.
    The problem is not to make it work - it does.
    I want to understand how to modulate the LED's capacitance.
    It's maybe more an electronics issue, not a PIC one at this time.
    Any idea?
    Roger
    Hi skimask,
    Any idea?
    I tried a few different things, added resistors, added small cap's in parallel with the LED, couldn't really get the results to change to get a larger 'range'. The results would 'shift' up and down, but never really stretch out the way I wanted them to.
    Are you trying to 'widen' the range of the number you get back from the function? In other words, instead of, say 0-10, you'd get 0-1000?
    The key might be finding the right LED vs. adding components to the circuit, or just plain counting it all really fast.
    As you can see from my page, basically, as soon as I got that to work, I called it good...something in the hobby toolbox for the future...
    Mar 2005
    Iowa, USA
    I've been doing some reading on this subject and had it in the back of my mind for sometime now, using an led as a switch instead of a mechanical switch. A few things that I've read that may influence the range your after are the color of the lens... I think a clear lens works better, and the amount of ambient light in the room. It would be an easy experiment to see how it reacts in total darkness compared to whatever your normal lighting conditions are. Here's a couple links for info.
    http://www.edn.com/article/CA6387024.html
    Check out some of the references at the bottom of the page. I especially like the reference to the Mitsubishi Electric Research lab paper.
    THIS is originally where I saw a demonstration. And ofcourse Skimask has video proof that it works, not to mention nice enough to post some code. Nice video!
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Quote Originally Posted by rhino View Post
    I tried a couple of type of red lensed LEDs, barely got any results at all. Tried a clear-greenish lensed, got some results, but nothing useful. The LEDs I ended up using were IR LEDs. You can barely see them in that 'video' I made. They show up on the camera, but you can't really see them.
    I sorta wrote the code to compensate for ambient lighting. I'd keep track of the high and low values and the one that was the darkest was the one with my finger over it. And the code on the site isn't exactly the finished product. The 'real' code (before I shelved the project) had a couple of extra lines in it to 'reset' the high and low values over time so they wouldn't get 'stuck'.
    That same video is where I got the original idea from.
    And of course Skimask has video proof that it works, not to mention nice enough to post some code. Nice video!
    (Code posting) - First time for everything I guess
    Someday, when I get my basement/LAB rework finished (major water damage, repainting walls in the works), I'll put it back together with a few more LEDs and redo the video. Bought the wife a new camera for Xmas last year (or was it me? I forget )...has a really decent movie mode on it.
    Default Lower the "RC time" is the aim
    Well,
    I see we all have been reading and viewing the same documents and medias already.
    I've tried this with lots of different LEDs (IR, simple colored red/ambre/green/yellow/blue/white, 7seg and even a bicolor one) and they ALL work. Of course, I get different results but it works always.
    Since the way to "measure" the LED with a PIC is to calculate it's discharging time (state change), to make it work fast, I want to REDUCE the "RC time".
    So, if now I'm counting around 4000 counts (see post #1) until the LED goes from state "1" to state "0", I want to speed-up things with lowering this value and make it become something around 100.
    How can I reach this?
    Depending on the surrounding luminosity, the scanning/counting process can vary from a few milliseconds to seconds.
    As mentionned in lots of articles, the surrounding luminosity affects tremendously the discharge time of the LED and compensation is mandatory.
    In my mind, the only way to compensate the longer discharging time due to surrounding darkness is to reduce the voltage applied to the LEDs.
    Is there another way?
    Roger
    Since the discharge is performed by the PIC itself, I don't see a way to speed the process unless you connect an external Transistor in parallel with the LED. A mosfet perhaps. But that will complicate the things...
  1. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  2. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  3. For next loop using: Led var Byte
    By quester in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 10:16
  4. LCD will not start
  5. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 13:27
