Wireless with DS18S20
Results 1 to 14 of 14
    Dec 2005
    Quote Originally Posted by lerameur View Post
    hi
    As for the ground and shielding, should I ground my antrenna or used a metal plate. I have a plastic box, is there a better method ? Of course the second wire of the antenna goes to the input..
    ken
    There's no need for anything special and shielding is usually superfluous unless the receiver is near (6-8') an RF noise source. There are commercial antennas available cut for 433.92MHz or you can build your own - it depends on the range needed. A 6 inch piece of wire attached to pin 8 of the receiver may be adequate. Or you can use one like those sold by Bruce Reynolds...or build one like...which can be built with any insulated solid wire stiff enough to hold its shape. The phasing line can be made from 75-ohm coax if 93-ohm isn't available.
    For the transmitter, a 6" wire is usually more than adequate.
    If you need extra range, add a wide-band preamp between the receiving antenna and receiver. Getting 150-200' through a few walls is usually possible.
    I've ordered one of the RX/TX pairs so I can test the receiver. In the meantime, can you tell me what the chip is on the receiver? I'm interested in the 24-pin chip - I can tell it's a HiMark chip but cannot read the number. I'm familiar with a HiMark 18-pin superheterodyne ASK receiver chip but cannot recall seeing a 24-pin chip.
    Sep 2006
    Ok I am getting better reception with grounded antennas.
    this is what is written on the 24 pin chip:
    0637
    BD69F1
    ken
  1. Wireless Tachometer - Design Help
    By DanPBP in forum Off Topic
    Last Post: - 3rd May 2009, 09:06
  2. RS485 Vs Wireless (TWS-434A)
    By koossa in forum Off Topic
    Last Post: - 11th April 2009, 12:40
  3. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 03:18
  4. Wireless communication gear.
    By toalan in forum Off Topic
    Last Post: - 17th March 2005, 16:33
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 10:36
