PIC 18F4550, firmware
Results 1 to 14 of 14
    May 2007
    Default PIC 18F4550, firmware
    I recently started to use PICBASIC PRO, and trying to write a code which will simply light a led. While using bootloader I recognized that I need to allocate some free space for firmware. How can I do this in PICBASIC? In CCS C, it is possible to write such a code like this.
    #build (reset=0x800)
    #build (interrupt=0x808)
    #org 0x0000, 0x07ff
    void bootloader () {
    #asm
    nop
    #endasm
    Quote Originally Posted by kutsi View Post
    #org 0x0000, 0x07ff
    #asm
    nop
    #endasm
    Which bootloader are you using?
    Which PIC are you using?
    Which version of PBP are you using?
    Why would you need to allocate free space for firmware while using a bootloader?
    How complicated is this 'shine an led' program of yours?
    May 2007
    I guess, firmware needs first 2kb of the memory.Therefore the first 800h bits must be allocated...
    PIC18F4550
    PICDEM FS USB DEMO TOOL VERSION 1.00
    PIC18F4550
    As long as your bootloader is supported by PBP, then you shouldn't have to worry about anything.
    What about the rest of the questions?
    May 2007
    Define ONINT_USED 1
    LED var PORTL.0 ' Alias PORTB.0 to LED
    loop: High LED ' Turn on LED connected to PORTL.0
    Pause 500 ' Delay for .5 seconds
    Low LED ' Turn off LED connected to PORTL.0
    Goto loop
    This is a simple example from the guide.
    Do I need to define anythin further? osc 20mhz?
    PBP 2.46
    Define ONINT_USED 1
    Goto loop
    PBP 2.46
    Which page is 'Define ONINT_USED 1' on in the guide?
    And since when does a PIC18F4550 have a PortL?
  1. Pic to Pic Firmware upgrade
    By rjones2102 in forum mel PIC BASIC Pro
    Last Post: - 13th October 2007, 01:06
  2. getting started with a PIC 18F4550
    By bigbear in forum General
    Last Post: - 16th October 2006, 03:31
  3. Build PIC bootloader firmware in PBP?
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 18th August 2006, 20:53
  4. Pic 18F4550 & VB6
    By lentz in forum USB
    Last Post: - 5th April 2006, 01:55
