Two LCDs on one PIC
Results 1 to 7 of 7
    Feb 2004
    Germany
    Default Two LCDs on one PIC
    As this has been asked several times:
    Here is an example how to connect two LCDs (or one LCD with two controllers) to the PIC.
    You need just one additional Port Bit to toggle between the two controllers.
    As only one Controller is enabled at a time
    and the LCD is initialized when the first LCDout command is issued
    you will need to reset the "INIT Flag" after the first LCD has been initialized.
    Then select the second LCD and send a "CLEAR" to initialize the second LCD.
    See PBP Manual Section 5.37
    Example:
    (assuming LCD-Select is connected to PortB.1)
    Add to the beginning of your code:
    LOW PortB.1 ' Select LCD 1
    LCDout $Fe,1 ' initialize and Clear LCD 1
    Flags=0 ' Reset "INIT-Flag"
    HIGH PortB.1 ' Select LCD 2
    LCDout $Fe,1 ' initialize and Clear LCD 2
    See the schematic:
    Here's another example of 2 LCD's on 1 PIC
    With this method, you can send to either LCD independantly, or to both LCD's at the same time. The only additional parts required are 2 resistors.
    By taking the LCD?_Disable pins LOW, it prevents the Enable signal from getting to that particular display. So, just disable the one you don't want to send to, and it sends the data to the one you want.
    This method can have more than 2 displays attached to the same pic. The only limitation is the number of pins that are available.
    DO NOT attempt to use the R/W pin on the LCD's! The displays will be damaged when more than 1 display is enabled at the same time.
    Here's a simple program:
    DEFINE LCD_DREG PORTB   ' LCD Data port
    DEFINE LCD_DBIT 0       ' starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB  ' LCD Register Select port
    DEFINE LCD_RSBIT 4      ' LCD Register Select bit
    DEFINE LCD_EREG PORTB   ' LCD Enable port
    DEFINE LCD_EBIT 7       ' LCD Enable bit
    DEFINE LCD_BITS 4       ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4      ' Number of lines on LCD
    LCD1_Disable  VAR  PORTB.5
    LCD2_Disable  VAR  PORTB.6
    LCDOUT  $FE,1   ' Initialize both LCD's
    PAUSE   200
    GOSUB  USE_LCD1
    LCDOUT "This is LCD 1"
    GOSUB  USE_LCD2
    LCDOUT "This is LCD 2"
    GOSUB  USE_BothLCD
    LCDOUT $FE,$C0,"Both LCD's"
    USE_LCD1:
        INPUT LCD1_Disable
        LOW   LDC2_Disable
    USE_LCD2:
        LOW   LCD1_Disable
        INPUT LDC2_Disable
    USE_BothLCD:
        INPUT LCD1_Disable
        INPUT LDC2_Disable
    Best regards,
       Darrel
    Jun 2008
    Varese , Italy
    Default Re: Two LCDs on one PIC
    Thanks a lot Darrel for the very simple solution to my problem: that is great !
    I have also seen that the INPUT command puts the pin to a three state condition: it is very good.
    Ambrogio
    IW2FVO
    North Italy
    Feb 2004
    Germany
    Darryl,
    have you really tried this setup?
    I think the LCD1_Disable and LCD2_Disable Pins on the PIC would have to OpenDrain to allow this to work properly.
    Setting LCDx_Disable High will set the E Input of tha attached LCD High and it will stay High, regardless of the state of the E Output of the PIC.
    So the LCD will never "see" a falling edge on E.
    regards
    You are correct. If the Disables are set HIGH it won't work.
    That's why it only gets set either LOW or INPUT (Tri-State, open-drain, etc.).
    You can see in the USE_LCD?: subroutines how they are switched.
       Darrel
    Feb 2004
    Germany
    Sorry Darrel,
    I should have had a look at your code example before posting.
    regards
    Jun 2008
    Varese , Italy
    Thanks for the assistance on the matter.
    Ambrogio
    i2w2fvo
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  3. Serial Pic to Pic using HSER
  4. Two LCDs on one PIC
    By lester in forum FAQ - Frequently Asked Questions
    Last Post: - 22nd February 2005, 03:28
  5. how to connect 2 LCDs on a PIC
    By f1fco in forum mel PIC BASIC Pro
    Last Post: - 15th April 2004, 18:59
