negatives
Results 1 to 7 of 7
Thread: negatives
    Depends on how you want to look at it.
    It can also be -1
    X  VAR BYTE
    X = 0
    X = X - 1
    LCDOUT SDEC X
    Displays -1 on LCD
    Feb 2005
    Kolkata-India
    Post Copy/Paste from the manual
    If any are preceded by an S (for signed), the output will be sent
    preceded by a “-“ if the high order bit of the data is set. This allows the
    transmission of negative numbers. Keep in mind that all of the math
    and comparisons in PBP are unsigned. However, unsigned math can
    yield signed results. For example, take the case of B0 = 9 - 10.
    The result of DEC B0 would be “255". Sending SDEC B0 would give “-
    1" since the high order bit is sent. So with a little trickery, the unsigned
    math of PBP can yield signed results.
    Sougata
    Feb 2005
    Kolkata-India
    Default I never knew that
    Thanks Darrel. This second post is because I have always skipped that portion of the manual and done it in hard way. Thanks again.
    Sougata
    I never knew that
    Can't say that anymore.
    Glad to help.
