Driving a DC motor /w 16f84a
Results 1 to 19 of 19
    Default Marching Onward . .
    Hi Lilmanmgf,
    This Sumobot you are building, Is it going to have reverse and forward, or only forward and stop? I ask because if you want it to have reverse, then an H-Bridge is what you are looking for. If it only goes forward, you might do as well or better with a fast acting relay, and lose the heatsink, MOSFETs and some of the confusion, you would likely still need a small switching transistor and a snubber diode. I know these bots are pretty small, and the space and weight saved might be useful for something else.
    JS
    Lilmanmgf's Avatar
    Lilmanmgf Guest
    Yeah, it just needs to go forward and stop.
    If you find MOSFETs confusing you may wish to use an H-Bridge IC. The SN754410 is a full H-bridge in a DIP package. I have successfuly used this chip to drive two motors forwards and backwards on a small robot. Heat dissipation has not been an issue. The operation of this chip is extremely easy to understand and the inputs can be driven directly from the PIC.
    If you would prefer to put your own H-bridge together you should definantly use MOSFETs. If you are having trouble with the on gate voltage from the PIC being to low you may try to connect a pull-up resistor from the gate of the MOSFET to the positive supply (this is assuming you are still running off of 9v). The pull-up would bring the gate to a full 9v when the PIC signal goes high but when the PIC ouput goes low the gate would be driven low. You should test your ideas out on a breadboard and find what works best.
    Hope this Helps.
    May 2007
    Harvest, Alabama
    Cool Mosfets and some tricks
    here are a few tricks you may wish to try.
    (1) MOSFETS love to be in parallel. This allows you to get the heat down a lot.
    (2) Overdriving the control a bit on MOSFETS (50% or less) is generally safe and causes really fast response. Read the specs on you MOSFETS yours may be able to do this.
    (3) Just for fun on the DC segment rather than killing the current entirely while running leave a modest few milliamperes hanging in the main drive coil at all times you are running the motor. It will drag the coil slightly but may affect current demand in the circuit a lot. This might well be worth the effort. This is a trick to prevent the collapse of the magnetic field in the coil of the DC motor. If it requires a voltage reversal, time this reversal when you are already into the next drive position some.
    Post Oh my God please PWM it!
    I didnīt read much of it, but you could do so many things!!.
    First of all i would recommend a PWM always for this DC motors, they are really Current eaters, if the 16f84 donīt has it (it doesnīt) you can provide something with a simple timer, and a word counter. increase the counter on each interrupt an play with its value to decide if the pin goes HIGH or LOW. I really recommend to meet at last the 16f628 you get so many more stuff that you will never go back to 16f84, youīll get for example a great PWM in one sentence.
    I have in my hands the irf530 right now, it should make the work; I donīt have the greatest memory but i do remember that this Motor is an inductor and it will help you to use a diode (1n4004 or a Switcher if using PWM) to reduce peak currents on the level change from ON to OFF, you might have used this diode on relays for the same purpose.
    If you canīt use different batteries for the motor and control (if you can then use an optocoupler) then be sure to add some capacitors to the uC Vcc-Vdd as close as possible (this is a classic one).
    Donīt know if you are also using a Vreg if you are he is the one shutting down after heating.
    Working with small batteries and getting power out of them is a real challenge, if you can go for a better source (you can usually do this for college asignments)
    May 2006
    Kedah, Malaysia
    Quote Originally Posted by Josuetas View Post
    I don't understand by what you guys mean PIC16F84a doesn't have PWM.
    We can use the pulseout command right?
    PULSOUT Pin,Period
    I have create a robot using the DC servo motor using PIC16F84a and the Motor speed (modified DC motor) and position can be controlled using the PWM command.
    To control DC Motor speed and to safe the power consumption we also can use the PWM method. But for DC motor we cannot easily control the angle of the rotation as the DC servo motor.
    ra68gi's Avatar
    ra68gi Guest
    Quote Originally Posted by fazan83 View Post
    PULSOUT Pin,Period
    By PWM they mean hardware PWM module see data sheet of 16f8xx.
    pic basic pro has got a command to use this its..
    HPWM Channel, dutycycle, frequency.
    PIC 16F84 does not have this hardware module so you can't use this command. But you do have a software pwm command..
    PWM pin, duty, cycle. but the disadvantage is...
    The PIC has to keep churning out pulses all the time not able to do other important things like adc measurement or rpm measurement etc which will be the feedback to control your motor. The second thing is the software pwm is only for a limited no of cycle & to keep it ON you need to give it or invoke the command again after the cycle is over.
    Pulseout command is commonly used as clock or some cases in hobby projects to control servo motors. but in all these cases the micro is made to spend all its time only to generate pulse. Log on to rentron.com & you will find some nice examples to use pwm to fire IR leds.
    Raghunathan.
  1. DC to AC convertor
    Last Post: - 6th February 2010, 18:44
  2. Replies: 24
    Last Post: - 1st December 2009, 09:01
  3. from 5v dc to 1.00v dc precise vref 10mA ?
    By phoenix_1 in forum Schematics
    Last Post: - 28th July 2009, 09:11
  4. PIC data along dc line
    By sswcharlie in forum General
    Last Post: - 30th August 2008, 09:38
  5. H-Bridge control DC motor
    By Paul F in forum General
    Last Post: - 11th March 2005, 13:50
