problem with 2*16 lcd
Results 1 to 7 of 7
    Quote Originally Posted by ibra View Post
    hi...
    the error message is..
    ERROR Line 61: Demo command limit of 31 exceeded. Time to purchase? (ibraheem.pbp)
    what is the problem...and i need a solution !!!!
    It compiles without error on my non demo version, so the most probable answer is yes, "time to purchase".
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Try this
    define lcd_dreg portd
    define lcd_dbit 4
    define lcd_rsreg portd
    define lcd_rsbit 2
    define lcd_ereg portd
    define lcd_ebit 3
    define lcd_bits 4
    define lcd_lines 2
    low portd.1
    lcdout $fe,1, "EMBEDED SYSTEMS pro."
    if portb.0=0 then l2
    lcdout $fe,1, "project1"
    while portb.0=1
    toggle portb.1
    pause 200
    wend
    l2:
    lcdout $fe,1, "project2"
    while portb.0=1
    Toggle portb.1
    pause 600
    wend
    I didn't check the logic ... it should do the same thing you originally coded (except with a few errors fixed like changing your returns to gotos.
    Last edited by paul borgmeier; - 29th April 2007 at 10:09. Reason: undid edit - as originally posted
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Quote Originally Posted by paul borgmeier View Post
    Try this
    define lcd_dbit 4
    define lcd_rsbit 2
    define lcd_ebit 3
    define lcd_bits 4
    define lcd_lines 2
    low portd.1
    while portb.0=1
    toggle portb.1
    pause 200
    wend
    l2:
    while portb.0=1
    Toggle portb.1
    pause 600
    wend
    Compiled for a 16f877a the codes as listed: 320 words for Ibra's code 309 for Paul's.
    Paul I think he is trying to compile using a demo version compiler and has too many lines of code for the demo version to handle.
    I have not even looked at the code to attempt to see if it works. I only addressed his complaint of compiler error.
    JS
    Edit: Looks as if you addressed that problem too, you got it down to 29 lines so his compiler should do it Good Job! I gotta pay closer attention!
    Apr 2007
    how to purchase??!!
    malc-c's Avatar
    malc-c Guest
    how to purchase??!!
    http://www.crownhill.co.uk/level3.php?cat=40
    there's a few Melabs distributor, as you didn't mention your location in your user profile, it's hard to suggest the closest place.
    I suggest to have a look at their distributor list
    http://melabs.com/purchase.htm#Distributors
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 09:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  3. LCD problem
    By Andre_Pretorius in forum General
    Last Post: - 27th January 2009, 16:47
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Need help with LCD number display.
