counter/ internal clock
Results 1 to 11 of 11
    Yes it could be 1uSec / clock cycle @4MHZ... but not in Basic code, even in assembler @ 4MHZ, you couldn't do it @ 4MHZ with a software loop, hence why TIMERs are built in.
    NOW, select a 16Bit timer that can be set as counter BY using the internal FOsc (ticks) and read the according register once in a while or in a loop. With some human measurement, you should be able to have a accuracy of few uSec.
    This will also require you configure the Timer prescaler and pre-load value accordingly. To help you to figure out their value, i suggest you download my PicMutiCalc
    http://www.mister-e.org/pages/utilitiespag.html
    EDIT: it's sunday and my brain need to understand better what you need to do... i'm lost in your explanation. Maybe you could translate it to Mister E's poor english level?
    Apr 2007
    Sorry for the poor explanation but I’m a little confused myself.
    From the proton geeks site I’ve modified the code snippet “How to build a simple and stupid small timer routine” by Olivier de Broqueville to achieve basically what I’m after.
    device = 16F876a  	   			  	  	   'PIC device
    CMCON = 7 								   'disable comparators
    ADCON1 = 7 								   'disable ADCs
    TRISB = %11111111 						   'Portb as inputs
    TRISA = %00000000 						   'Porta as outputs
    porta = %00000000 						   'Set all outputs low
    	ON_INTERRUPT Horloge
    	DECLARE XTAL=4
    	SYMBOL GIE  = INTCON.7
    	SYMBOL T0IF   = INTCON.2
    	SYMBOL T0IE   = INTCON.5
    	SYMBOL PS0 = OPTION_REG.0
    	SYMBOL PS1 = OPTION_REG.1
    	SYMBOL PS2 = OPTION_REG.2
    	SYMBOL PSA = OPTION_REG.3
    	SYMBOL T0SE= OPTION_REG.4
    	SYMBOL T0CS= OPTION_REG.5
    	DIM mycounter as  WORD 	 ' This is the TIME variable used to count the interrupts
    	DIM mycounter_limit as WORD   ' This is the limit to reach. Could have been a constant in the program
    					   	  		 ' to win some place (you would win 6 words)
    	DIM SECONDS as BYTE
    	GIE=0
    	GOTO INITIALISATION			 ' As always: place interrupt routine first and jump over...
    ' INTERRUPT ROUTINE
    Horloge:
    				INC mycounter	' Increment the time variable at every interrupt
    				T0IF=0			' Clear the interrupt flag
    				CONTEXT RESTORE
    Initialisation:
    			   T0SE =0	 	   ' TIMER0 triggered by ascending edge
    			   T0CS =0	 	   ' TIMER0 using internal clock
    			   PSA  =0	 	   ' Prescaler assigned to TIMER0
    			   PS0  =1	 	   ' Prescaler set at 1:256
    			   PS1  =1
    			   PS2  =1
    			   mycounter_limit= 10
    			   mycounter=0
    			   SECONDS=0
    			   TMR0=0	 ' Reset TIMER0
    			   T0IE=1	 ' Autorisation of TIMER0 interrupt
    			   GIE=1	 ' Autorisation of all interrupts
    MAIN:
     	 		   WHILE 1=1   		 		   	   			 ' Do this forever
    			   IF mycounter > mycounter_limit Then		 ' Are we above the TIME factor?
    			   	  			  				   			 ' As the test is ABOVE the clock runs a bit
    														 ' slow, which was the purpose
    			   	     mycounter=0						 ' Reset the 'interrupt' counter
    			   	     SECONDS=SECONDS+1					 ' Increment the seconds
    					 IF SECONDS > 59 THEN				 ' If 59 sec,
    						SECONDS=0						 ' and RESET seconds
    			   if SECONDS > 5 then
    			   porta =%00000001
    			    porta =%00000100
    				'Stop for 5 sec and
    				'check PIR
    				end if
    			   WEND	 	   	  		   		   				' And do it forever
    But I don’t really understand how it works as I managed to get approximately the required time by setting “mycounter_limit= 10” (trail and error).
    He gives an explanation here : linky
    but as I’m using 4mHz OSC the values are different. Can anyone help explain whats happening in the code as I never like to use something with out fully understanding it.
    Jim
    Mentor, Ohio
    Smile
    Hi JimBob,
    There are alot of examples of basic Timer usage on this forum. Nuts and Volts magazine (www.nutsvolts.com) did an article on using Timers last year. This is a topic that has been more than covered in the last couple of years. There are examples with explanations of using timers in, for example, Easy Clocks by Paul Borgmier and Ms. Melanies' Olympic Timer and her MN1302 Clock program. You can also get examples on the www.melabs.com website under sample programs. Mister E has provided you with an excellent program for determining what values you need to enter when setting up timers.
    I am not trying to be critical but look around, this information you need to learn is out there and easy to find.
    HTH,
    BobK
  1. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 18:44
  2. Setting up internal clock correctly?
    By JohnM in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 21:29
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. 16F688 Internal clock and MCLR
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 18th August 2007, 19:38
  5. 16F628 Internal clock
    By srob in forum mel PIC BASIC Pro
    Last Post: - 15th February 2007, 19:46
