Keypad and DT's Instant Interrupts
Results 1 to 12 of 12
    Question Keypad and DT's Instant Interrupts
    DOH! I had a detailed question but it got cleared. So here's the short-short version.
    Has enybody included a 4x4 keypad routine in with DT's instant interrupts? It would most likely use port B change to trigger. I found forum references to keypad and interrupts but since I'm using the elapsed timer routine anyway I think I should stick with the "instant interrupts" technique. Can it be done with a change in variable value?
    (Flanders hippie dad) "We tried nothing, and nothing ain't working"?
    Homerclese
    You can still use a Timer interrupt with my KEYPAD.BAS routine. Just use the DEFINE SCAN_ONCE 1 in your settings.
    Thread:
    http://www.picbasic.co.uk/forum/showthread.php?t=3250
    i've attach the latest version... just in case of.
    Thanks for the quick response.
    I have tried the code and it works. However there is an issue. I have a 4x4 setup but it acts like a 4x3 keypad. I can get digits 1 through 12. If I change the define as below to 4 col then nothing works. Im still checking but I think this is the same hardware setup I had before and it worked as a 4x4. Any suggestions?
    TRISB = %11110000 'PortB first four bits outputs second four bits inputs
    include "KeyPad.bas"
    DEFINE KEYPAD_ROW 4 ' 4 ROW keypad
    DEFINE KEYPAD_ROW_PORT PORTB ' ROW port = PORTB
    DEFINE KEYPAD_ROW_BIT 4 ' ROW0 = PORTB.4
    'DEFINE KEYPAD_COL 3 ' 3 COL keypad
    DEFINE KEYPAD_COL 4 ' 4 COL keypad
    DEFINE KEYPAD_COL_PORT PORTB ' COL port = PORTB
    DEFINE KEYPAD_COL_BIT 1 ' COL0 = PORTB.1
    DEFINE KEYPAD_DEBOUNCEMS 20 ' debounce delay = 20 50 mSec
    DEFINE SCAN_ONCE 1
    OPTION_REG.7=0 ' Enable internal crap pull-up
    ADCON1=7 ' disable ADCs
    PORTB = 0 '
    ByteA var byte '
    Homerclese
    mmm, it's working here as suppose to. Using your code above on a 16F877, i tried with...
    <font color="#000000">    @       __CONFIG _XT_OSC &amp; _LVP_OFF
        <font color="#000080">INCLUDE </font>&quot;C:\PBP_PROG\INCLUDE_ROUTINES\KeyPad.bas&quot;
        <font color="#000080">INCLUDE </font>&quot;c:\PBP_PROG\EASYPIC4\LCD4.bas&quot;
        <font color="#000080">DEFINE </font>KEYPAD_ROW 4 	 <font color="#008000">' 4 ROW keypad
        </font><font color="#000080">DEFINE </font>KEYPAD_ROW_PORT PORTB <font color="#008000">' ROW port = PORTB
        </font><font color="#000080">DEFINE </font>KEYPAD_ROW_BIT 4 	 <font color="#008000">' ROW0 = PORTB.4
        </font><font color="#000080">DEFINE </font>KEYPAD_COL 3 	 <font color="#008000">' 4 COL keypad
        </font><font color="#000080">DEFINE </font>KEYPAD_COL_PORT PORTB <font color="#008000">' COL port = PORTB
        </font><font color="#000080">DEFINE </font>KEYPAD_COL_BIT 1 	 <font color="#008000">' COL0 = PORTB.0
        </font><font color="#000080">DEFINE </font>KEYPAD_DEBOUNCEMS 20  <font color="#008000">' debounce delay = 20 50 mSec
        </font><font color="#000080">DEFINE </font>SCAN_ONCE 1
        OPTION_REG.7=0 	         <font color="#008000">' Enable internal crap pull-up
        </font>ByteA <font color="#000080">VAR BYTE
        PAUSE </font>500
        <font color="#000080">LCDOUT </font>$FE,1,&quot;PRESS ANY KEY&quot;
    Start:
        @ READKEYPAD _ByteA
        <font color="#000080">IF </font>ByteA <font color="#000080">THEN
            LCDOUT </font>$FE,$C0,<font color="#000080">REP </font>&quot; &quot;\2,$FE,$C0, <font color="#000080">DEC </font>ByteA
            <font color="#000080">ENDIF
        GOTO </font>Start
    make sure you have disable the LVP mode and there's no faulty I/Os
    I will check further. I am using the f877 pic. Note that I tried changing this line to "4". Is that wrong?
    DEFINE KEYPAD_COL 3 ' 4 COL keypad
    Looking at it now I realize that its probably 0 to 3 which is 4 states or columns. So the above line should stay as it is?
    Homerclese
    using the previous but changing KEYPAD_ROW or KEYPAD_COL number it always work for me. Yeah, even a 1X1 keypad work... wooohoo how handy it is
    Now, using a TIMER0 interrupt and DT-INT14, it looks like
        <font color="#000080">INCLUDE </font>&quot;C:\PBP_PROG\INCLUDE_ROUTINES\DT_INTS-14.bas&quot;
        <font color="#000080">INCLUDE </font>&quot;C:\PBP_PROG\INCLUDE_ROUTINES\ReEnterPBP.bas&quot;
    <font color="#000080">ASM
    INT_LIST  macro
            INT_Handler   TMR0_INT,  _TMR0Interrupt,   PBP,  yes
        INT_CREATE
        </font>OPTION_REG=%00000100    	 <font color="#008000">' Enable weak-pull ups
    </font>                            	 <font color="#008000">' Prescaler assigned to Timer0
    </font>                            	 <font color="#008000">' rate 1:32
        </font>TMR0IF <font color="#000080">VAR </font>INTCON.2
        <font color="#000080">PAUSE </font>500
        @ INT_ENABLE  TMR0_INT
    Start:
        GOTO </font>Start
    TMR0Interrupt:
        @ READKEYPAD _ByteA
        TMR0=0
        @ INT_RETURN
    and it's still working.
    do a I/O test with LEDs and push button to see if there's any faulty.
    KEYPAD_COL 3 really set the KeyPAd to 3 column, DEFINE KEYPAD_COL_BIT 1 will imply you're connected to PORTB.1, PORTB.2, PORTB.3
    same for rows, DEFINE KEYPAD_ROW 4, 4 rows, DEFINE KEYPAD_ROW_BIT 4, so PORTB.4, PORTB.5, PORTB.6 and PORTB.7.
