Bootloader Hardware Modification
Results 1 to 2 of 2
    Feb 2004
    Germany
    Default Bootloader Hardware Modification
    Many of you are using a BootLoader with a standard BootLoader Hardware (Loader Cable with MAX232)
    You may have realised that this cable can't be used for serial communication with other devices.
    (i.e. PIC to PC Communication using HyperTerm)
    The Reason is: MCLR on the PIC is pulled permanently LOW by the external device. (DTR on the DB9)
    A small modification on the BootLoader Hardware makes Life a lot easier.
    The attached schematic shows the standard BootLoader Hardware and the required modification.
    (Replace the 100 Ohms Resistor with a 10uF Tantalum Capacitor)
    see schematic:
    Feb 2004
    Germany
    There is yet another modification that might be of interest:
    If you have a MAX232 on your board, wired as in the BootLoader example, there is one spare driver.
    If there is any device on your board that requires a negative (supply) Voltage
    (i.e. LCDs with extended temperature range need a negative "contrast" voltage)
    Pull T2IN (Pin10) of the MAX232 HIGH and T2OUT (Pin7) will provide that negative voltage.
    rgds
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 17:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  3. 18F2550 MCRL/RE3 problem with USB bootloader Microchip
    By Ronald123 in forum mel PIC BASIC Pro
    Last Post: - 24th September 2007, 10:48
  4. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 22:29
  5. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 17:51
