You need magnetic shielding, not electrical snubber.
The motor case will provide some shielding, but if the case is thin or low permeability, the field will pass through. You have earth grounds, good cable, good connections, etc. This is all that is left.
Several ways to do the shielding, with out seeing the setup I can only make a couple of suggestions.
Wrap the BIG motor in a material with a high magnetic permeability and/or the same around the enclosure with the hal-effects.
Google magnetic shielding This site looks like it has good info http://www.lessemf.com/mag-shld.html.
Post a picture or two and maybe we can be of more help.
THANK YOU VERY MUCH for the suggestion.
I will put pictures as soon I will mount another machine.
