Originally Posted by
mackrackit
Just thinking that when the board moves close to the big motor a strain is put to the connector / solder joint / etc.
Sounds like you checked all that as I thought you would have.
Do I have this correct? The only problem is -- when board gets to close to the big motor, RA.4 does not receive a signal. Every thing else is working "OK".
