Can examples!
Results 1 to 9 of 9
Thread: Can examples!
    Apr 2007
    Yes I know its difficult to manage the ECU but thats not what I want.
    We built security vehicles and use PLC systems today.
    I communicate with canbus to controll central lockings,windows etc.
    This is not hard to control but now I want to do this with my own PIC based controller.
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Quote Originally Posted by jkbpower View Post
    You're not interested in the ECU? Then how will you manage to read speed and other data as your first initial post stipulates.
    Everything in the CAN except the ECU is node. If you can't understand the ECU then how can you talk to the nodes? I'm puzzled.
    Jun 2005
    Wisconsin
    Actually communicating with one vehicle is the same as the next, because they all use the OBDII protocol. The SAE have the OBDII standard for purchase. While some of the more advanced functions like reprogramming are manufacturer specific the diagnostic items like speed and RPM are the same on every vehicle and outlined in their document(s).
    I had the oppritunity to read through the OBDII standard while working on another project, needless to say its tedious to communicate on the buss. I ended up integrating an OBDII to serial IC into my design to simplify things, ELM electronics sells it (ELM327).
    The following will give you a taste of the protocol and how it works. This document is geared to VPW but the concepts remain the same.
    http://www.lightner.net/lightner/bruce/Lightner-183.pdf
    That ELM327 chip rocks!
    I'm about to order a 2nd load of PCBs anydays now. Almost can't keep enough on hand.
    Aug 2005
    You said anything.Attached are code files that appear to be PBP.I downloaded them from somewhere about 6 years,but never used them.I do know they were for use with a can bus interface chip MCP2510 controlled thru the MSSP port of a 16F877 using SPI.
    Apr 2007
    Thanks!
    Maybe I can use some of that code.
    The 18F6585 have an own ECAN modul so I think its a lot different than using the stand alone chip.
    But I´m going to look at this.
    Oboy!!! I have a lot to learn about CAN :-)
    /JKBPower
    CAN is nice, but not as easy as USART, SPI, I2C or some part of USB.
    At least once you understand the concept, it's easy.
  1. Examples for EasyPIC
    Last Post: - 13th July 2013, 15:56
  2. i2c non-eeprom examples?
    By justDIY in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2010, 19:07
  3. Definitive MPLAB Config Examples
    By Brian J Walsh in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 12:33
  4. PICPROTO 18 Prototyping Board Examples
    By rick hardy in forum General
    Last Post: - 21st April 2008, 06:19
  5. Code Examples
    By Archangel in forum Forum Requests
    Last Post: - 30th June 2007, 10:34
