turning leds on and off
Results 1 to 3 of 3
    mertkon's Avatar
    mertkon Guest
    Default turning leds on and off
    hi i have just started to picbasic. i tried to control led by button but i could not be successful.
    i wrote a code like this
    DEFINE OSC 48
    DEFINE RESET_ORG 800h
    TRISB.3 = 0
    TRISB.7 = 1
    low portb.3
    buttons:
    if portb.7 = 0 then 'if button is pressed
    high portb.3 'turn on led
    if portb.7 = 1 then
    low portb.3
    goto button
    but at this code only while i am pressing the button led turns on and when i pull my finger back from the button it turns off. but i want led to turn on up to next pressing of button. what should i do. thanks for help and sorry for my english
    Read your code! It's doing exactly what you tell it to do!
    ----------------assume the button is pressed to start with
    low portb.3 ----- starts off LED off
    buttons:
    if portb.7 = 0 then 'the button is pressed, light the LED
    high portb.3
    if portb.7 = 1 then 'the button is pressed, so don't light the LED
    low portb.3
    goto button
    Now the other way around...assume the button is not pushed...........
    buttons:
    if portb.7 = 0 then 'the button is not pushed, so this if/then does not execute
    high portb.3
    if portb.7 = 1 then 'the button is pressed, so light the LED
    low portb.3
    goto button
    And besides all that, at the end, don't you want to 'GOTO BUTTONS' instead of 'BUTTON'???
    What you probably want is something like this:
    DEFINE OSC 48
    TRISB.3 = 0 : TRISB.7 = 1 : state var bit : state = 0 : portb.3 = state
    buttons:
    portb.3 = state 'turn the led on or off according to the state bit
    if portb.7 = 1 then 'if button is not pressed, don't do anything
    goto buttons
    if portb.7 = 0 then 'if the button is pressed
    if state = 0 then 'if the LED was off last time...turn it on...
    state = 1
    state = 0 'otherwise turn it off (since it was on last time)
    waitforrelease:
    if portb.7 = 0 then
    goto waitforrelease 'wait for the button to be released before checking it again
    goto buttons
    Think about it for a bit...
    Jan 2006
    Istanbul
    Try this, too.
    <font color="#000000"><b>.
    </b><font color="#0000FF"><b>LED </b></font><font color="#000080"><b>VAR </b></font><font color="#0000FF"><b>PORTB</b></font><b>.</b><font color="#FF0000"><b>3
    </b></font><font color="#0000FF"><b>Btn </b></font><font color="#000080"><b>VAR </b></font><font color="#0000FF"><b>PORTB</b></font><b>.</b><font color="#FF0000"><b>7
    </b></font><font color="#0000FF"><b>LED </b></font><b>= </b><font color="#FF0000"><b>0
    </b></font><font color="#0000FF"><b>Start</b></font><b>:
    </b><font color="#000080"><b>IF </b></font><font color="#0000FF"><b>Btn </b></font><b>= </b><font color="#FF0000"><b>0 </b></font><font color="#000080"><b>THEN
       WHILE </b></font><font color="#0000FF"><b>Btn </b></font><b>= </b><font color="#FF0000"><b>0 </b></font><b>: </b><font color="#000080"><b>WEND
       TOGGLE </b></font><font color="#0000FF"><b>LED
    </b></font><font color="#000080"><b>ENDIF
    GOTO </b></font><font color="#0000FF"><b>Start
    </b></font>
