Thanks Skimask,
I checked out the thread and had the same problems and tried to fix them the same way but to no avail.
I am just going to keep changing to HS when I program for now as I have a bigger problem.
When I use MPASM 5.03 instead of PM all my serout2 commands seem to send out zeros. Also I programmed a small loop sending out a string and compiled using PM and all worked well, when I did the same with MPASM it would not change even when I deleted lines they kept being there. I changed the setting of INHX in the assembler settings of Mcode Studio and it programmed but again sent blank strings.
Do you have any ideas, I used MPASM in the past without any problems but not this version, is it maybe that the latest version is not compatable?
Chris
