How to set up UART??
Results 1 to 9 of 9
    Apr 2007
    This is what my 18F6585.INC file look like!
    ;* 18F6585.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2003 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 06/19/03 *
    ;* Version : 2.44 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    "Error: PM does not support this device. Use MPASM."
    NOLIST
    LIST
    LIST p = 18F6585, r = dec, w = -302, f = inhx32
    INCLUDE "P18F6585.INC" ; MPASM Header
    ; __CONFIG _CONFIG1H, _OSC_XT_1H
    ; __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
    ; __CONFIG _CONFIG4L, _LVP_OFF_4L
    __CONFIG _CONFIG1H, _OSCS_OFF_1H & _OSC_HSPLL_1H
    __CONFIG _CONFIG2L, _PWRT_ON_2L
    __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    __CONFIG _CONFIG4L, _LVP_OFF_4L & _STVR_OFF_4L & _DEBUG_OFF_4L
    __CONFIG _CONFIG5H, _CPD_OFF_5H
    __CONFIG _CONFIG6H, _WRTD_OFF_6H
    NOLIST
    LIST
    EEPROM_START EQU 0F00000h
    BLOCK_SIZE EQU 8
    Apr 2007
    I forgot to say that I dont run the pic at 10Mhz as I said erlier.
    I use HSPLL function and run it at 40MHz.
    /JKBPower
    Quote Originally Posted by jkbpower View Post
    /JKBPower
    Then you have to DEFINE OSC 40 'cause it's running at 40Mhz, not 10Mhz
    Apr 2007
    Yes, I use OSC 40.
    But still not working as it should.
    Maybe I have something wrong in my design with the MAX232 curcuit.
    I will do a check to if it works.
    Apr 2007
    Hi again,
    hmm.. its a little embarrassing.
    I´ve got it working now.
    I just had to shift the RX and TX line on the RS232 cable. hehe.
    I took the scope and saw that both my pic and the PC tried sending data on same line.
    But I got lot of help from you anyway. Like this PicMultiCalc software :-)
    /JKBPower
  1. Pin won't stay high during Repeat...Until loop??
    Last Post: - 17th August 2009, 00:57
  2. Interruptus Frustratus
    Last Post: - 17th April 2009, 21:36
  3. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
