12F508 strange timing
Results 1 to 6 of 6
    Jan 2006
    Istanbul
    GP3 is always an input pin no matter what you do.
    Also, when you set a pin as an output pin, like you frequently do in your code, the weak pull-up register won't work the next time the same pin is set to be an input pin.
    If you assign a pin as an input pin AFTER you set it to an output pin previously, then you need to register to weak pull-up register again.
    Ah, ...
    Last but not least ...
    is MCLR configured as "internal MCLR" ... ???
    didn't see anything about ...
    PS: May be THIS .asm listing could help ... same function, but rotation selected by TWO pins ( stop allowed ...) !!!
    Apr 2007
    [QUOTE=Acetronics;36807]Ah, ...
    Thanks for the reply Alain,
    I modified the inc file and set MCLR_OFF.
    I've since refined it, it has nothing to do with the blocks of code. Pulling GPIO low slows the chip down. It has this effect on the simplest of code (flashing led). Tonight I'll write something in C to see if it's a language thing.
    The circuit is a friends, I'll draw a schematic from the board layout and see if he's done anything hinkey..
    PK
  1. 12F683 serout timing
    By Hobie Cat in forum mel PIC BASIC Pro
    Last Post: - 21st December 2009, 16:57
  2. Convert code 12C508 to 12F508
    By Olivier in forum General
    Last Post: - 25th October 2009, 16:19
  3. 18F2550 timing
    By sstt1976 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2008, 00:30
  4. HSEROUT buffering and timing - 16F88
    By picster in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 17:52
  5. Strange ASM file
    By barkerben in forum General
    Last Post: - 29th November 2004, 18:54
