12F508 strange timing
Results 1 to 6 of 6
    Apr 2007
    Default 12F508 strange timing
    My circuit uses GP3 as an input (I modified 12F508.inc) and INTRC_OSC
    The second block of this code (starting with the lable ccw loops at about 1/6th of the speed of the bit below the if statement???
    Anyone seen anything like this?
    Many thanks in advance
    PK
    OPTION_REG.5=0 'need to set this to use pin2 as an output
    OPTION_REG.6=0 'this turns on the internal pull up resistors
    stepDelay con 20 'delay in mS for each step
    TRISIO=%01000 'set GPIO.3 as an input, all othe pins as outputs
    loop: if GPIO.3=1 then ccw
    GPIO=%00110
    pause stepDelay
    GPIO=%00101
    pause stepDelay
    GPIO=%10001
    pause stepDelay
    GPIO=%10010
    pause stepDelay
    goto loop
    ccw: GPIO=%10010
    pause stepDelay
    GPIO=%10001
    pause stepDelay
    GPIO=%00101
    pause stepDelay
    GPIO=%00110
    pause stepDelay
    goto loop
    Quote Originally Posted by pk7639 View Post
    You know this doesn't affect all GPIO pins...right?
    Talking
    PK
    GPIO=%00110
    pause stepDelay
    GPIO=%00101
    pause stepDelay
    GPIO=%10001
    pause stepDelay
    GPIO=%10010
    pause stepDelay
    goto loop
    ccw: GPIO=%10010
    pause stepDelay
    GPIO=%10001
    pause stepDelay
    GPIO=%00101
    pause stepDelay
    GPIO=%00110
    pause stepDelay
    goto loop
    May be I've missed something ...
    but I see here you write the state of an input pin ... Try to write each pin one after each other instead of the whole port at once !!!
    or better ... During the PAUSE, place the whole port as input, write your OUTPUT pins pattern ( 1 per 1 ), and AFTER, change for needed outputs with TRISIO ...
    that is what we do for having directly output pins in a certain config, at power up ...
    Jan 2006
    Istanbul
    GP3 is always an input pin no matter what you do.
    Also, when you set a pin as an output pin, like you frequently do in your code, the weak pull-up register won't work the next time the same pin is set to be an input pin.
    If you assign a pin as an input pin AFTER you set it to an output pin previously, then you need to register to weak pull-up register again.
    Ah, ...
    Last but not least ...
    is MCLR configured as "internal MCLR" ... ???
    didn't see anything about ...
    PS: May be THIS .asm listing could help ... same function, but rotation selected by TWO pins ( stop allowed ...) !!!
    Apr 2007
    [QUOTE=Acetronics;36807]Ah, ...
    Thanks for the reply Alain,
    I modified the inc file and set MCLR_OFF.
    I've since refined it, it has nothing to do with the blocks of code. Pulling GPIO low slows the chip down. It has this effect on the simplest of code (flashing led). Tonight I'll write something in C to see if it's a language thing.
    The circuit is a friends, I'll draw a schematic from the board layout and see if he's done anything hinkey..
    PK
  1. 12F683 serout timing
    By Hobie Cat in forum mel PIC BASIC Pro
    Last Post: - 21st December 2009, 17:57
  2. Convert code 12C508 to 12F508
    By Olivier in forum General
    Last Post: - 25th October 2009, 17:19
  3. 18F2550 timing
    By sstt1976 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2008, 01:30
  4. HSEROUT buffering and timing - 16F88
    By picster in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 18:52
  5. Strange ASM file
    By barkerben in forum General
    Last Post: - 29th November 2004, 19:54
