so the @ symbol tells the programmer that the line is asembly code directly and not PBP code and the other text just activates, or in this case deactivates the features of the PIC that I list. The serin command does store my incoming data into the variable that I put at the end and the serout sends that data that's in the brakets. But I'm worried that since I'm using an exterior 20MHz oscillator (with capacitors from the input of the oscillator to ground and from the ouput of the oscillatorto ground) that the timing might be off. I made a IF/THEN loop that sends a high pauses and sends a low then incraments my variable and will continue till my variable reaches 3 and the pauses were much to long when writen as "PAUSE 500". I thought this would pause 0.5 seconds since I used DEFINE OSC 20, but it didn't, it did however pause for about one second when I set it to "PAUSE 2". Any thoughts?
