AlaskanEE -
Hint....
Read Section 12.0 as Skimasks suggests, review table 12-1. Now go to pg. 52 and review table 5-2. Look at the column that tells you what the POR, BOR and value after all other resets is. What does it tell you about the default setting of the registers in table 12-1?
Here's another good tool. Use this LINK to search the forums. It seems to work better than the built in search tool.
