I2C with any PIC?
Results 1 to 13 of 13
    Quote Originally Posted by BigWumpus View Post
    ...just try to code a slave-I2C !
    Then you will see, what advantages a hardware-modul can give to you !
    ...and it gives you so much performance, if you use the hardware in an intelligent way!
    Somewhere out there, is a site with practically complete I2C-slave code, uses the hardware and PBP to handle things. Apparently it works like a champ. A 2nd PIC18F452 is slave-I2C programmed to act just like a 24LC256 and it's accessed by the 1st 18F452 using PBP's I2C commands. Wish I remembered where that was...
    Many of us have done this but for professional reasons we are unable or unwilling to share the code. However, Robert Soubie detailed his adventures with I2CSlave using Melabs PICBasic, and posted all his code here...
    http://www.astrosurf.com/soubie/pic_as_an_i2c_slave.htm
    Well done Robert!
    Nov 2008
    Hi Melanie,
    i tried Roberts I2C Slave routine, but it is not clear how to access the Slave with I2CREAD / I2CWRITE with Melabs PBP from the Master.
    In the I2CREAD and I2CWRITE commands are also "address" parameters given, is this the same to be used as the parameter RXBuffer(0)?
    Does any one have an exmaple for me?
    Ralf
    Other than telling you that Robert achieved the goal that many seek but few accomplish, and he documented everything on his website (I'm assuming it's all still there), I can't add any more, because I haven't actually tried his software myself.
    Nov 2008
    Hello Melanie,
    yes there is a lot on the website, but there is not describd how to access it with I2CREAD / I2CWRITE. May be i am blind.... Maybe anyone else can help...?
    Ralf
    Quote Originally Posted by ralfmayr View Post
    Hello Melanie,
    Ralf
    from the second page of his web site:
    http://www.astrosurf.com/soubie/fichiers/i2cInt.pbp
    http://www.astrosurf.com/soubie/fichiers/Proc_i2c.pbp
    You would still use I2CREAD and I2CWRITE as per normal in the Master PIC. It's only the slave PIC that would use the new routines.
  1. I2C Master/Slave 16F88/16F767 working code
  2. HARDWARE I2C SAMPLE CODE question
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
  4. Use pic as slave in I2C
    By robert0 in forum General
    Last Post: - 3rd February 2006, 19:26
  5. Adding a pic in I2C network....
    By robert0 in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2005, 12:07
