I2C with any PIC?
Results 1 to 13 of 13
    Feb 2005
    Kolkata-India
    Default PBP uses a software I2C
    PBP uses a software based I2C so it does not actually matter if your chip has an onboard hardware I2C. It will never use it.
    Sougata
    SWITZERLAND (french speaking)
    Thanks Sougata,
    This is what I thought since I use a 12F675 and a 24LCxxx memory via I2C and this PIC has no specific I2C interface (...and, of course, it works).
    So what is the "advantage" or simply the reason for certain PICs to have a I2C interface?
    Roger
    well, usually faster than most software solution, usually provide interrupts triggers, etc etc etc. Same for USART (HSERIN/HSEROUT) against SEROUT/SERIN etc etc.
    Hangover, Germany
    Talking
    ...just try to code a slave-I2C !
    Then you will see, what advantages a hardware-modul can give to you !
    ...and it gives you so much performance, if you use the hardware in an intelligent way!
    Quote Originally Posted by BigWumpus View Post
    Somewhere out there, is a site with practically complete I2C-slave code, uses the hardware and PBP to handle things. Apparently it works like a champ. A 2nd PIC18F452 is slave-I2C programmed to act just like a 24LC256 and it's accessed by the 1st 18F452 using PBP's I2C commands. Wish I remembered where that was...
    Many of us have done this but for professional reasons we are unable or unwilling to share the code. However, Robert Soubie detailed his adventures with I2CSlave using Melabs PICBasic, and posted all his code here...
    http://www.astrosurf.com/soubie/pic_as_an_i2c_slave.htm
    Well done Robert!
    Nov 2008
    Hi Melanie,
    i tried Roberts I2C Slave routine, but it is not clear how to access the Slave with I2CREAD / I2CWRITE with Melabs PBP from the Master.
    In the I2CREAD and I2CWRITE commands are also "address" parameters given, is this the same to be used as the parameter RXBuffer(0)?
    Does any one have an exmaple for me?
    Ralf
  1. I2C Master/Slave 16F88/16F767 working code
  2. HARDWARE I2C SAMPLE CODE question
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
  4. Use pic as slave in I2C
    By robert0 in forum General
    Last Post: - 3rd February 2006, 19:26
  5. Adding a pic in I2C network....
    By robert0 in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2005, 12:07
