I modified my code and am getting the 8 bytes but seem to keep running into buffer overflows. Can you see an error in my interrupt routine?
@ device hs_OSC, wdt_on, pwrt_on, protect_off
define osc 20
Include "modedefs.bas"
trisc.6=0
TRISC.7=1
TRISA.0=0
RCSTA = %10010000 ' ENABLE USART AND SET TO CONTINUOUS RECEIVE
SPBRG = 64 'SET TO 4800bps
INTCON = %11000000 'ENABLE GLOBAL & PERIFERAL INTERRUPTS
RCIF VAR PIR1.5 'FLAG IS THE INTERRUPT WHEN A BYTE IS IN THE USART BUFFER
RCIE VAR PIE1.5
OERR VAR RCSTA.1
CREN VAR RCSTA.4
test var porta.0
BAUD CON 16390
BUFFER VAR BYTE[10] 'BUFFER FROM USART TO COLLECT THE 8 BYTES
BYTECOUNTER VAR BYTE 'USED TO COUNTER BYTES INTO THE BUFFER
BFULL VAR BIT 'FLAGS THAT THE BUFFER HAS ALL 8 BYTES
VALUE VAR BYTE 'A TEMP SINGLE BYTE RECEIVED FROM THE USART
COUNTER VAR WORD 'USED FOR LOOP IN MAIN PROGRAM
BUFFER = 0
BYTECOUNTER = 0
BFULL = 0
VALUE = 0
RCIE=1 'ENABLE USART RECEIVE INTERRUPT FLAG
ON INTERRUPT GOTO GETDATA
GOTO MAIN:
disable
'====================INTERRUPT ROUTINE ==============================
GETDATA:
IF RCIF=1 THEN
VALUE=RCREG
IF VALUE = $A0 THEN 'CHECK TO SEE IF THE BYTE IS THE START BYTE
BYTECOUNTER=0
RCIF=0
IF BYTECOUNTER < 8 THEN
BUFFER[BYTECOUNTER] = VALUE
BYTECOUNTER=BYTECOUNTER+1
'CHECK IF OVERRUN HAS OCCURRED:
IF OERR=1 THEN
Serout2 test,BAUD,["OERR",10,13] 'TO SHOW OVERFLOW
PAUSE 1000
CREN=0 'STOP CONTINUOUS RECEIVE
CREN=1 'RESTART CONTINUOS RECIEVE & CLEAR THE OVERRUN FLAG
BYTECOUNTER=0 'RESET COUNTER AS PART OF PACKET HAS BEEN LOST SO START AGAIN
BUFFER=0
GOTO GETDATA
IF BYTECOUNTER=7 AND BUFFER[0]=$A0 AND BUFFER[6]=$AF THEN
GOTO MAIN
GOTO GETDATA
RESUME
ENABLE
MAIN:
'ON INTERRUPT GOTO GETDATA
if counter= 1000 THEN 'SEND PELCO VALUE EVERY FEW LOOPS
serout2 test,BAUD,["BUFFER=",HEX BUFFER[0],",",HEX BUFFER[1],",",HEX BUFFER[2],",",HEX BUFFER[3],",",HEX BUFFER[4],",",HEX BUFFER[5],",",HEX BUFFER[6],",",HEX BUFFER[7],10,13] 'JUST CHECK 1ST 2 VALUES
toggle portd.1 'LED TO INDICATE TO ME THAT THE LOOP IS LOOPING
counter=0
counter=counter+1
