Pls How can I make 16F877A use 15MHz Xtal
Results 1 to 31 of 31
    Las Vegas, Nevada, USA
    Default 15MHz on 16F877A
    No need to edit your INC file. Just add a line of assembler to your program:
    @ DEVICE HS_OSC
    Then add a line of PIC Basic:
    DEFINE OSC 20
    I don't believe Pic Basic Pro can use 15MHz properly. See page 170 of Compiler manual: "The acceptable oscillator definitions are: . . . 12, 16, 20 . . ." If you use "DEFINE OSC 15", I believe PIC Basic will default to 4MHz, but then you have changed "DEVICE XT_OSC" to "DEVICE HS_OSC", so it may not work at all.
    Jul 2006
    Hey, what's wrong with "condensers," I always thought it made sense...just cram (condense) those little electrons in there until no more will fit. ;-)
    As for "resonators," the more I learn about "resonance," the more methinks the numbers have a "little" something to do with harmonics. I'll stick with what the design specs state.
    Got a few laughs from this thread.
    Chris Helvey
    Talking
    Hi, Chris
    a Condenser is something generally used to change physical phase ( from gas state to liquid state ... see how to make bad Whisky or alcohol ... i.e ... or how your climate works).
    Jul 2006
    Wink
    I was being tongue and cheek, of course. But really, there is a part on my air conditioner full of Freon that must be 10,000uF! It runs hot though...
  1. 16F877A with 20MHz XTAL not working?
    By ustredna in forum mel PIC BASIC Pro
    Last Post: - 19th August 2011, 15:04
    Last Post: - 14th November 2008, 17:25
  3. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 18:52
