Pls How can I make 16F877A use 15MHz Xtal
Results 1 to 31 of 31
    Apr 2007
    Unhappy Pls How can I make 16F877A use 15MHz Xtal
    Hi I am using a PIC 16F877A in my project. The Project works fine with a 4MHz crystal but when I replace the 4MHz crystal and its associated capacitors with a 15 MHz crystal and associated capacitors, The pic does not work
    Does anyone know what needs to be done in PIC basic to make the 16F877A work?
    Quote Originally Posted by ozzie1st View Post
    XT vs. HS...
    Look in the datasheets.
    Apr 2007
    Unhappy XT vs HS
    My understanding is that to use 15 MHz crystal i need to include
    DEFINE OSC 15
    at the top of my pic basic pro codes
    and that I needed to edit the 16F877A.INC file on my C: drive and replace XT_OSC with HS_OSC.
    I have done this. Is there anything I am not doing? Thanks
    DEFINE OSC 15
    XT vs. HS. Check the datasheets
    You have to reconfigure your PIC to run the 15mhz oscillator.
    And check your PBP manual for the correct use of:
    DEFINE OSC 15
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Skimask is hinting that you read section 7.1 of the manual (and pay particular attention to the table)
    ... and I think he wants 15MHz, not 15mHz .... 1,000,000,000X difference
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Quote Originally Posted by paul borgmeier View Post
    Good call. At least I didn't say 15uhz...or 15phz...or 15fhz and keep going...and going...and going...
    Default ? ? ? ? ? !
    Hi Paul,
    _ D'oh I think I missed something here, mHz != MHz by a billion times, What the heck is mHz if not megahertz? Please forgive my American ignorance of this little part of the Metric system but they didn't teach that in school in those days.
    JS
    Hi Paul,
    JS
    Unwritten rules I think...Probably hinting that:
    mhz = milli hertz
    Mhz = mega hertz
    kinda like
    bps = bits per second, while
    Bps = could be taken as BYTES per second
    I would take it that way if I didn't have anything else to base it on...meaning if I didn't know we were talking about megahertz I might think we might've been talking about milli hertz...
    Talking RTFM ... ha,ha,ha ... I REALLY LOVE !!!
    DEFINE OSC 15
    geeeee !!! What a wonderful forum is has become these days ...
    after all these years, I didn't know there was a DEFINE OSC 15 ...
    12 or 16 only available ... too bad !!! ( Manual p. 170 ... )
    but ... PBPIC libs can be modified, of course !!! ... or time related functions re-calculated ... isn't it ???
    PS: Sorry Ozzie, but it will be VERY difficult to run off-the-list frequencies with straight PBP ... try 16 Mhz !!! it will be so much simpler ...
    May be some ones here could explain you how to modify the PbPlib files ... to run a True 15 Mhz Xtal !!!
    I'd really love to read them too ... humour.
    Apr 2007
    Smile
    Thankjs SKIMASK, thanks Paul. I got it working!! Muchos Gracias;-)
    T.Jackson's Avatar
    T.Jackson Guest
    There is actually a variant of the 877a that is limited to 4MHz. 877a-20p will work up to 20MHz
    Apr 2007
    Thumbs up Yes PBP will not compile with DEFINE OSC 15
    T.Jackson,
    Yes not to mislead anyone; I typed 15 loosely here. It could have been 8, 16 20 etc; I simply couldnt get any crystal (8, 20, 16 etct) to work. OF course PBP will not compile with DEFINE OSC 15. But it did compile with the listed frequecies 16MHz, 24MHz etc. However at the time I entered this thread I did not know that PBP wil not work with 15
    However Thanks to the forum I now know better and I am actually using a 24MHz crystal;-)
    Feb 2003
    Smile
    Hi Ozzie,
    Now that everything is fine, it is not. This time you need to check the datasheet. You will see that 24MHz is beyond the specified limit of DC-20MHz. You are "overclocking" the PIC and performance is not implied.
    Hi Alain, you quoted skimask's reply from post#4 and then wrote this
    for clarification, skimask did not suggest using DEFINE OSC 15, the OP did (post#3). Skimask hinted that the OP might want to check the manual (post#4).
    in otherwords, skimask asked him to fish (post#4), I baited the hook (post#5), and you gave him a fish (post#13).
    EDIT: and I had a little fun with the m M thing along the way (Trent also noted the 20MHz top limit above)
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    T.Jackson's Avatar
    T.Jackson Guest
    T.Jackson,
    I'm unaware of any variant of the 877a that can be clocked as high as 24MHz.
    Maybe I'll send you my special one that was clocked at 32Mhz for awhile.
    I don't know why it worked, but it did. Would it work under all conditions, using all modules, under all combinations of code? Probably not, but it worked for me.
    (Yes, I know it's a one-off situation and they're only rated for 20Mhz)
    Talking rocket pics ...
    Hi, Skimask
    ALL the pics I use are "overclocked" to their max. "µChip" freq. ... my old 16F84-04, 16F628-04, 16F876-04, 16F877-04 and else happily run @ 20 mhz.
    32 Mhz is not really surprising nor, I often read about !!!
    this fact is well known, also well known those chips have not being TESTED over the whole voltage, temp. and freq. range !!!
    Just keep in mind those overclocked chips are not guaranteed by µChip ... that's the only point to care with when professionnal use !!!
    May be we also might point out that , these days, "Non Rohs" devices are sold at a really fair price ...
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Nah I'll be right. Not in the habit of challenging large teams of professional engineers. The data sheet says 20 - that's as far as I go.
    Las Vegas, Nevada, USA
    Default 15MHz on 16F877A
    No need to edit your INC file. Just add a line of assembler to your program:
    @ DEVICE HS_OSC
    Then add a line of PIC Basic:
    DEFINE OSC 20
    I don't believe Pic Basic Pro can use 15MHz properly. See page 170 of Compiler manual: "The acceptable oscillator definitions are: . . . 12, 16, 20 . . ." If you use "DEFINE OSC 15", I believe PIC Basic will default to 4MHz, but then you have changed "DEVICE XT_OSC" to "DEVICE HS_OSC", so it may not work at all.
    Jul 2006
    Hey, what's wrong with "condensers," I always thought it made sense...just cram (condense) those little electrons in there until no more will fit. ;-)
    As for "resonators," the more I learn about "resonance," the more methinks the numbers have a "little" something to do with harmonics. I'll stick with what the design specs state.
    Got a few laughs from this thread.
    Chris Helvey
    Talking
    Hi, Chris
    a Condenser is something generally used to change physical phase ( from gas state to liquid state ... see how to make bad Whisky or alcohol ... i.e ... or how your climate works).
    Jul 2006
    Wink
    I was being tongue and cheek, of course. But really, there is a part on my air conditioner full of Freon that must be 10,000uF! It runs hot though...
  1. 16F877A with 20MHz XTAL not working?
    By ustredna in forum mel PIC BASIC Pro
    Last Post: - 19th August 2011, 15:04
    Last Post: - 14th November 2008, 17:25
  3. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 18:52
