PIC16F676 Problem
Results 1 to 7 of 7
    Sep 2006
    Florida, USA
    Smile I think you're on to it!
    Skimask - Thanks for the info - this would explain why I have been able to do this task on other chips - I have always been using a 20 mHz resonator. This is the first time that I am not. I'll try this out and post my results.
    Thanks again!
    Sep 2006
    Florida, USA
    Talking
    Skimask - Your info worked perfectly. My pot-controlled servo is now working just fine! Thanks for your help!!!
    Here is my updated code:
    @ DEVICE pic16F676, INTRC_OSC_NOCLKOUT
    CMCON = 7
    ANSEL = %00000000 ' Turn off analog input
    TRISC = %00000001
    RCVal var Word
    Posit var word
    PotIn var PORTC.0
    Servo var PORTC.3
    low servo
    MoveServo:
    gosub readpot
    'produce a value between 75 and 255 when running at 4 mhz
    posit = 75 + rcval + (rcval / 2)
    'produce a value between 350 and 950 when running at 20 mhz
    'Posit = 350 + RCVAL
    PULSOUT Servo, posit ' move the servo
    pause 25
    goto MoveServo
    ReadPot:
    'At 4 mhz, returns 0-120. At 20 mhz, returns 0-600
    ' with a 10K pot and 0.1 uf cap
    high potin
    pause 1
    rctime potin, 1, rcval
    I think I'd change your 'Pause 25' to something a bit lower.
    Servo's want to be updated at about 50-60hz. You've got it set up for no more than 37hz update rate (pause 25 + 1ms minimum pot read + 1ms minimum pulsout).
    I'd put it somewhere around Pause 14 or so...to give a minimum of 50hz.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. 16F676 Please explain this problem...
    By Jayhovah in forum mel PIC BASIC Pro
    Last Post: - 9th May 2008, 22:30
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. LCD Problem witch PIC16F676
    By microuser in forum mel PIC BASIC Pro
    Last Post: - 12th August 2005, 09:11
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
