Thanks Skimask. I tried your code and it did the same thing. The problem must be on my board. I will look closer at my circuit and let you know what I find. Atom058
My program was flawed. Timing isn't right for a 4mhz oscillator.
Try replacing the 1000 and 2000, with 100 and 200.
In fact, in your original program, change the line:
posit = rcval + 350
to
posit = rcval
and see what happens.
The pulsout command at 4mhz sending out pulses in increments of 10us.
You're minimum pulse width the way you wrote the program would automatically send out a pulse width of 3500us (3.5ms) which is above the 2ms (average) pulse width for a servo. If this works, post back. You might only have a little bit of POT movement for a lot of servo movement, but that part of the program can be rewritten to compensate for that. (think pause statement instead of pulsout)
Skimask - Thanks for the info - this would explain why I have been able to do this task on other chips - I have always been using a 20 mHz resonator. This is the first time that I am not. I'll try this out and post my results.
Thanks again!
Skimask - Your info worked perfectly. My pot-controlled servo is now working just fine! Thanks for your help!!!
Here is my updated code:
@ DEVICE pic16F676, INTRC_OSC_NOCLKOUT
CMCON = 7
ANSEL = %00000000 ' Turn off analog input
TRISC = %00000001
RCVal var Word
Posit var word
PotIn var PORTC.0
Servo var PORTC.3
low servo
MoveServo:
gosub readpot
'produce a value between 75 and 255 when running at 4 mhz
posit = 75 + rcval + (rcval / 2)
'produce a value between 350 and 950 when running at 20 mhz
'Posit = 350 + RCVAL
PULSOUT Servo, posit ' move the servo
pause 25
goto MoveServo
ReadPot:
'At 4 mhz, returns 0-120. At 20 mhz, returns 0-600
' with a 10K pot and 0.1 uf cap
high potin
pause 1
rctime potin, 1, rcval
I think I'd change your 'Pause 25' to something a bit lower.
Servo's want to be updated at about 50-60hz. You've got it set up for no more than 37hz update rate (pause 25 + 1ms minimum pot read + 1ms minimum pulsout).
I'd put it somewhere around Pause 14 or so...to give a minimum of 50hz.
