PIC16F676 Problem
Results 1 to 7 of 7
    Sep 2006
    Florida, USA
    Question PIC16F676 Problem
    Hello - I am trying to use a 676 to control a servo motor via a pot using RCTIME. I have done this many times with other PICs with no problem but for some reason I can't get it to work with the 676. I have poured over the posts and the datasheet and still no results. When I power up the PIC, the servo runs over full clock-wise and pegs out. Any ideas on what I am missing? Thanks! Atom058
    Here is the code:
    @ DEVICE pic16F676, INTRC_OSC_NOCLKOUT
    CMCON = 7
    ANSEL = %00000000 ' Turn off analog input
    TRISC = %00000001
    RCVal var Word
    Posit var word
    PotIn var PORTC.0
    Servo var PORTC.3
    low servo
    MoveServo:
    gosub ReadPot
    posit = rcval + 350
    PULSOUT Servo, posit ' move the servo
    pause 25
    goto MoveServo
    ReadPot:
    high potin
    pause 1
    rctime potin, 1, rcval
    cmcon=7 : ansel=0 : trisc=1 : posit var word : servo var portc.3 : low servo
    for posit = 1000 to 2000 : pulsout servo,posit : pause 15 : next posit
    for posit = 2000 to 1000 step -1 : pulsout servo,posit : pause 15 : next posit
    That should run your servo back and forth.
    If it does, you've got problems with your POT input.
    If it doesn't, you've got problems with your servo hookup.
    But you probably already knew that.
    Your offset of 350 might be wrong.
    Try using the POT command instead of RCTIME.
    Sep 2006
    Florida, USA
    Thanks Skimask. I tried your code and it did the same thing. The problem must be on my board. I will look closer at my circuit and let you know what I find. Atom058
    Quote Originally Posted by Atom058 View Post
    My program was flawed. Timing isn't right for a 4mhz oscillator.
    Try replacing the 1000 and 2000, with 100 and 200.
    In fact, in your original program, change the line:
    posit = rcval + 350
    to
    posit = rcval
    and see what happens.
    The pulsout command at 4mhz sending out pulses in increments of 10us.
    You're minimum pulse width the way you wrote the program would automatically send out a pulse width of 3500us (3.5ms) which is above the 2ms (average) pulse width for a servo. If this works, post back. You might only have a little bit of POT movement for a lot of servo movement, but that part of the program can be rewritten to compensate for that. (think pause statement instead of pulsout)
    Sep 2006
    Florida, USA
    Smile I think you're on to it!
    Skimask - Thanks for the info - this would explain why I have been able to do this task on other chips - I have always been using a 20 mHz resonator. This is the first time that I am not. I'll try this out and post my results.
    Thanks again!
    Sep 2006
    Florida, USA
    Talking
    Skimask - Your info worked perfectly. My pot-controlled servo is now working just fine! Thanks for your help!!!
    Here is my updated code:
    CMCON = 7
    TRISC = %00000001
    RCVal var Word
    Posit var word
    PotIn var PORTC.0
    Servo var PORTC.3
    low servo
    MoveServo:
    gosub readpot
    'produce a value between 75 and 255 when running at 4 mhz
    posit = 75 + rcval + (rcval / 2)
    'produce a value between 350 and 950 when running at 20 mhz
    'Posit = 350 + RCVAL
    pause 25
    goto MoveServo
    ReadPot:
    'At 4 mhz, returns 0-120. At 20 mhz, returns 0-600
    ' with a 10K pot and 0.1 uf cap
    high potin
    pause 1
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. 16F676 Please explain this problem...
    By Jayhovah in forum mel PIC BASIC Pro
    Last Post: - 9th May 2008, 22:30
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. LCD Problem witch PIC16F676
    By microuser in forum mel PIC BASIC Pro
    Last Post: - 12th August 2005, 09:11
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
