Off Topic?? - Serial coms.
Results 1 to 10 of 10
    Default Would this work?
    A quick idea. Have not tried.
    Input from Serial charges cap. When voltage is high enough to start pic, P1 goes high switching signal to P2. P2 receives signal. P3 sends signal. Cap would be 4700 or larger.
    I'd use a small battery pack rather than a cap, trickle charge the pack off the serial line when you can, diode block it so the pack can't feed back into the data line. Cap's are too unreliable in cases like this.
    You might be right about the caps being unreliable, but the current is so low on the lines it might take some time to charge the battery pack.
    Question - I thought RS485 voltage was negative without a signal on the line?
    My original idea came from thinking about RFID chips.
    If it is, then hook the battery up backwards
    Seriously...I'm thinking that even a small battery with an intial charge on it would probably maintain thru the '485 line. And a '675 should be able to run on sub-milliamp current.
    How often will the RX be powered, what's it's average daily 'duty cycle'?
    More fun to hook caps up backwards.
    Now you're speaking my language...
    I always say 'Everything comes prepackaged with a certain amount of smoke. You let that smoke out, it quits working.' (goes for cars too)
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Thanks blokes, I have found a thing called Pbus which looks promising so I'm gunna have a further look at it.
    Peter Moritz.
    New South Wales,
    Australia.
  1. Replies: 33
    Last Post: - 19th March 2010, 04:02
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  4. Serial coms with a pc
    By Andre_Pretorius in forum Serial
    Last Post: - 18th June 2007, 15:41
  5. PIC16F819 serial coms
    By c6jones720 in forum Serial
    Last Post: - 13th June 2007, 20:46
