SEROUT problem
Results 1 to 3 of 3
Thread: SEROUT problem
    martarse's Avatar
    martarse Guest
    Question SEROUT problem
    Hello,
    There is the code that I used for testing communication between PIC16F84A and RS232 computer port :
    include "modedefs.bas"
    define CHAR_PACING 1000
    define OSC 8
    here: serout porta.1,T9600,["Hello"]
    serout porta.1,T9600,[" MartiN "]
    goto here
    For the moment I just want to send information to the serial port. When I used this code I'm not able to see the message "Hello Martin " on the computer port.
    I've try with and without CHAR_PACING and I've try many other mode like T1200, T2400 and does not seems to work. I see only garbadge on the port.
    My oscillator (HS mode) is a 8MHz xtal with 22uF Cap.
    The connection between DB9 port and Pic is a 1K resistor as described in the PBP documentation for SEROUT command.
    someone can help me to read the good character on the serial port???
    thanks!!
    Hi Martin, try N9600 then it should work.
    T is used when you have a RS232 driver which invert the signal.
    Brgds Roy SM0MKJ
    martarse's Avatar
    martarse Guest
    Hello Roy,
    I've just test it and it works very well!
    Thanks for your help.
  1. A Serial GLCD 128x64 Simple Project
    By Oldspring in forum Off Topic
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
  3. Advice-scrutiny for my serial controller
    By kevlar129bp in forum mel PIC BASIC Pro
    Last Post: - 13th December 2008, 18:11
  4. Strange SerOut Problem
    By masosi in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2007, 07:06
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
