Init
Results 1 to 15 of 15
Thread: Init
    Sep 2005
    Campbell, CA
    Default Init
    I'm pondering several projects that require at least slight modifications to MCLoader. Most of them need to know the address of the PBP "INIT" location, so I can jump to it when I'm done doing my "stuff".
    I'm really curious as to how MCLoader figures out this location, since it loads BEFORE the PBP program. Can anyone enlighten me as to how this all works?
    Charles Linquist
    Feb 2005
    Kolkata-India
    Default The reset vector is at a fixed offset
    Charles I am not sure if I understood your question actually ? Here is a portion from the PBP library.
        ifdef LOADER_USED
      LIST
        ORG RESET_ORG + 8 		; Make sure no library code in first 4 locs
      NOLIST
    Rather than having a reset vector at 0x0000 PBP/MCS offsets this. Interesting to know this coincides with the int vector which is followed by NOP inserted by PBP. So when you are actually using interrupts this is replaced by a goto to your interrupt routine. I think that all this is according to how your code is laid out. The microcode loader on startup from the reset vector tries to handshake and if found just starts programming your PIC without ever touching the first 4 locations. So I think it may be location 0x0005 where you need to jump. Better decompile your hex and take a peek.
    Sougata
    Sep 2005
    Campbell, CA
    I'll check, but I don't thank that is it.
    Charles Linquist
    Feb 2005
    Kolkata-India
    Default Could elaborate a little more?
    Charles could you give an example as to what your exact requirements are ? Seems interesting. I have been pondering on issues of update-able protected firmwire. I need that the client may update a firmwire themselve but cannot effectively use it to dupe chips. Seems I need some sort of licensing firmware inside the PIC and a custom bootloader at the PC side.
    Sougata
    Charles,
    I thought we already figured that out?
    Still not working?
    Sep 2005
    Campbell, CA
    Yes, I used your technique of creating the variable 'INIT' inside an ASM block that was at the end of my PBP code. That worked fine.
    If you remember, the goal was to make a "hardware write protected bootloader" - one that could (hopefully) be loaded in the field without a PIC programmer. I put MCLoader in all chips. You also have to understand that a LOT of my stuff goes to the military, and they have some strange requirements, hence the demand for this "write protect" feature.
    I wrote a program (in PBP) that "field-patches" MCLoader. I got to the upper half of the 18F8722's program space by modifying PBPP18.LIB with a new system variable ('UPMEM') that loads into TBLPTRU. By setting this to "1" I can use READCODE, ERASECODE and WRITECODE in upper half of FLASH. If UPMEM is "0" these commands work in the lower half.
    My PBP program changes the MCStudio jump vector at 0x00 from 0x1fd04 to 0x1fcd0, and adds a statement at 0x1fcd0 to jump to 0x1fd04 (the start of MCLoader).
    That takes care of the first-time load using the bootloader - we load ALL our code, including the first time, using MCLoader.
    Next, my actual PBP application contained an ASM block at the end with an ORG at 0x1fcd0. It checked whether a pin was high or low, and decided either to jump to 0x1fd04 or INIT. The bootloader was invoked when the pin was low (it is pulled up) or else it jumps to the program start, bypassing the autoloader. This gave the "write protect" feature I was looking for.
    So far, so good - except for one thing... The FLASH is automatically erased before programming. Since my new jump vector at 0x00 pointed to a normally unused address in the codespace, if programming was interrupted before MCLoader could get the application all the way "in", the chip could no longer be programmed in the field - it is back to the factory time. This can be a real pain if the board is deeply embedded in some submarine, tank or airplane.
    I really wanted to locate the "new addition" to the bootloader (the test for pin high or low) to an address ABOVE MCLoader. There are a few more than 64 bytes above the top of that program in an '8720 or '8722. This is handy, since the block size of the ERASE in both chips is 64 bytes.
    So, I re-wrote my "bootloader patcher" to change the 0x00 vector to 0x1ffc0 (which is a few bytes above the top of MCLoader). I also wrote my "test for pin state" (and a few other things) in assembly and put its start address at
    0x1fc0. I found, by inspecting a lot of code, that PBP was always setting the INIT address to 0x59a, so I test for my pin state and jump to either 0x59a or 0x1fd04, the start of MCLoader.
    So far, it has been working perfectly, and the good thing is that I can pull the power plug halfway through programming, and later restart the programming cycle. My only concern is that I have my INIT vector hard-coded at 0x59a, and I'm worried that it won't always work.
    WHEW!
    Charles Linquist
  1. Help Pbasic to PBP
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2009, 18:35
  2. Using LPT port dot matrix printer with PIC
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 27th January 2007, 11:48
  3. Startup power higher than while program running - why?
    Last Post: - 11th December 2006, 10:25
  4. RS232 to Parallel Printer Converter
    By Squibcakes in forum Code Examples
    Last Post: - 19th September 2006, 16:11
  5. do i need to init the CG or DD in 4 bit lcd?
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 17th May 2005, 02:18
