hi . can someone help me ?
Results 1 to 4 of 4
    Jun 2007
    Default hi . can someone help me ?
    hi everybody .
    i wish to find someone help me here .
    am working with pic18f4550 and i need to configure it as 8 analog input (
    connected to variable resistor ) - 8 digital input (0-1) - 8 digital output .
    i did it but i cant make the analog part code .
    so . can some one help me to do it . ( i need the pbp code + vb code )
    thanks .
    here's something to help you to start
    USBDemo, something to learn USB a little bit
    http://www.picbasic.co.uk/forum/showthread.php?t=5418
    Jun 2007
    Default thank you .
    thanks alot dear .
    but when am trying to compile it i get :
    "overwriting previous address contents (0000)"
    "overwriting previous address contents (0001)"
    "overwriting previous address contents (0002)"
    "overwriting previous address contents (0003)"
    "overwriting previous address contents (0004)"
    "overwriting previous address contents (0005)"
    "overwriting previous address contents (0006)"
    "overwriting previous address contents (0007)"
    and when am trying to delete the first asm block in the pbp code it compiling
    good . so what is the problem ?
    Quote Originally Posted by amenoera View Post
    thanks alot dear .
    A simple search on just the word 'overwriting', would give you this:
    http://www.picbasic.co.uk/forum/show...=6775#post6775
    which most likely contains the answer to your problem...
