Writing and reading to a 24LC1025
Results 1 to 7 of 7
    Quote Originally Posted by Angus Anderson View Post
    I am developing a weather station logging system uses a 16F877 and should write 16 bytes of daily data to a 24LC512 EEPROM. Using I2C, I have a DS1307 (which works fine) connected on the same bus as the 24LC512. However, I cannot write or read succesfully to the EEPROM at all. the 3 address pins on the 512 are grounded. After trying unsuccessfully to write & read in page mode, I went back to the "Really simple" example in the PBP handbook, which I still cant get to work - instead of reading a 6 back, I get 255
    Angus Anderson
    Do a search here on the site for 24LC1025. There was another person awhile back had similar problems with the larger I2C eeproms, got it working with the advice in that thread, something about splitting the address into two seperate bytes in the command line, not really sure.
    Thanks Skimask. Will report back
    Bombay, India
    Angus Anderson, the 24LC1025 is expecting an 16 bit address. You are only sending it an 8 bit address.
    Dave, you were right about the 16 bit address
    I've managed to solve the problem by:
    1) Making the address a word sized variable
    2) Changing the pullup resistors from 4k7 to 2k7
    3) Taking the data to be stored and saving it Highbyte and Lowbyte so:
    I2cWrite SDA,SCL,$A0,Address,[Databyte.Highbyte]
    Address = Address+1
    I2cWrite SDA,SCL,$A0,Address,[Databyte.Lowbyte]
    Address = Address+1
    It now works like a charm. Thanks all of you for your advice, not the least by being reminded to take the trouble to do a search of the forum first ;-)
    Angus Anderson, That's good you got it working. I use 4 of the 24LC1025's for a fishing device I designed and it records 18+ hours of various data.
  1. Reading, writing, erasing flash (16F88)
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 09:13
  2. Writing & Reading to iButton EEPROM
    By crhomberg in forum Code Examples
    Last Post: - 6th October 2008, 20:40
  3. Reading and Writing from SD/MMC cards as FAT filesystem?
    By charliez in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2006, 23:26
  4. reading, writing, and displaying from eeprom
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 12th January 2006, 23:05
  5. Writing / Reading EEPROM 24LC256 Problem
    By schmoddel in forum mel PIC BASIC Pro
    Last Post: - 27th February 2004, 19:55
