USART with INTERRUPTS
Results 1 to 13 of 13
    Apr 2007
    Santiago, Chile
    Unhappy USART with INTERRUPTS
    Hi All,
    I have never used the USART of the PIC 16F877A and I used to use Serin2 in a loop to check for packets of 8 bytes which came to control a PTZ video camera. As the pic had other things to do you can imagine it missed messages from time to time.
    I tried using the sample program USART.bas but when I connected the RX to the serial program of Microcode Studio and sent single bytes out and then wrote a serin2 command to send rcreg back, the value was always different and many times the same value arrived back when I entered a different one.
    I was sending my data to the RX via com1 and receiving using serout2 via com2.
    This was my code:
    @ device hs_OSC, wdt_on, pwrt_on, protect_off
    'OPEN USART
    define osc 20
    Include "modedefs.bas"
    RCSTA = %10010000 ' Enable USART receive
    SPBRG = 31 ' Set baud rate to 4800 (20MHz clock)
    INTCON = %11000000
    PIE1.5=1
    trisc.6=0
    TRISC.7=1
    TRISA.0=0
    test var porta.0
    counter var word
    BAUD CON 16390
    loop:
    on interrupt goto myroutine
    if counter= 5000 THEN 'just to keep the pic busy to make sure the
    toggle portd.0 ' interrupts are working.
    COUNTER=0
    counter=counter+1
    INTCON = %11000000
    goto loop
    goto loop
    disable
    myroutine:
    if PIR1.5=1 then
    serout2 test,BAUD,[dec rcreg,10,13] 'send the value to com2
    serout2 test,BAUD,["PIR1.5=",BIN PIR1.5,10,13]
    IF RCSTA.1=1 THEN
    serout2 test,BAUD,["BUFFER OVERRUN",10,13] 'Just to see if overflow occured
    resume
    enable
    Best Regards
    Christopher in Santiago
    Try this instead....
    define osc 20
    RCSTA = %10010000:SPBRG = 31:INTCON = %11000000:PIE1.5=1:trisc.6=0
    TRISC.7=1:TRISA.0=0:test var porta.0:counter var word:BAUD CON 16390
    ---------------------------------jump over your interrupt routines
    disable
    myroutine:
    if PIR1.5=1 then
    IF RCSTA.1=1 THEN
    -------------------read the serial port input register and reset the input interrupt flag
    x=rcreg : PIR1.5 = 0
    resume
    enable
    toggle portd.0:counter=0 ' interrupts are working.
    counter=counter+1
    You're program organization was messed up a bit. Also, you have to read RCREG and reset the flag manually when using the serial port, just like the datasheet says.
    Which version of PBP are you using?
    Apr 2007
    Santiago, Chile
    Default Strange echos
    Thanks for correcting my code but at 9600 baud (BRGH=31 for 20MHz)
    When I send decimal 1 I receive 103
    2 = 51
    3 = 102
    4 = 25
    5 = 101
    6 = 50 etc
    I am using the code just as your wrote it?
    What have I set up wrong, I checked the baud rates on the terminal program.
    Chris
    Apr 2007
    Santiago, Chile
    Question USART Problems
    How would I achieve the same end result by using HSERIN,
    I tried but it seemed to just freeze even when I sent byte by byte to ensure
    I did'nt get a buffer overflow?
    Chris
    Quote Originally Posted by crhomberg View Post
    If you're using SEROUT2 to send characters back to the PC, you need to go back and read the PBP manual on how to use it. And, you have to set up a few more registers to get the UART receive port working correctly. Read the UART section in the datasheet for a bit and come back with your results...
    And which version of PBP are you using?
    So, all you're really trying to do right now is get a 'loop back' to work?
    define osc 20
    trisc.6=0:trisc.7=1:trisd.0=0:serialdata var byte : counter var word : counter2 var word
    counter=counter+1 : portd.0 = counter.1 'toggle led on portd.0 each time thru the loop
    serialdata=0:serin portc.7, n9600, serialdata:if serialdata=0 then goto main 'get serial data, if none, restart loop
    counter2 = counter2 + 1:serout portc.6, n9600, [ dec counter2 , ":" , serialdata , 13 , 10 ]:goto main
    Apr 2007
    Santiago, Chile
    Unhappy USART Problems
    Thanks SkiMask,
    I have used and tested SEROUT2 many times without a hitch, it is sending test values just as I send them.
    As far as reading the USART manual, I have been reading it for the last 2 days.
    I am getting square eyes but seem to have missed something.
    You saw how I used SEROUT2 in my code (is it wrong?)
    Maybe I should just use HERIN instead
    Chris
    Apr 2007
    Santiago, Chile
    Yes, just a loopback
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
  5. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
