Correct
Will do again - didn't make a difference last time
Will do
Yes
Will do
I don't have one unfortunately - an LED flashes like mad though...
Have checked that many times!
4MHz with capacitors as drawn
Correct
Will do
Yes
Will do
My computer won't talk to a serial modem anymore... and it won't echo its own data from Tx to Rx either...
That explains it!
Then a new question pops up... How was the serial JDM2 programmer verifying the PIC's contents? (I know the PIC was being programmed successfully too!)
Anyway, I'll get my hands on a new set of serial ports tomorrow
Skimask and Paul, thankyou so much for your help so far! I've learnt alot even though the ideas havn't solved my problem! Thanks again!
In post 5 I asked about the PC port, and you said that the same thing happened on another computer. ?????
As far as the programmer software reading back correctly, all I can say is it happens. I have a PICKIT1 that will read back errors if I use the software that microchip supplied, but mplab does not. Both software work. I would guess in this case the "lesser" software does not have something correct in its receiving side, like a checksum miss calc.
Again, check the signal with a meter. TX will show low (Maybe even a negative value) when idle and will spike anywhere from 2.5 to 25 V+ at transmit. If you have a machine less than 10 years old or using a usb/serial adpt, you will most likely see 2.5 to maybe 6.
The new serial ports let everything behave as it should!
I wish I knew the port was dead 2 weeks ago!!!
Thanks again everyone, very good help
Tom.
