Strange SerOut Problem
Results 1 to 40 of 40
    Feb 2003
    Salt Lake City, Utah USA
    Smile stuff to try
    1) Are you sure you have pin 2 correct and pin 5 correct (you are using a 9 pin connector that is straight thru?) see http://www.airborn.com.au/rs232.html
    2) Try it without TX connected
    3) A must - add a decoupling capacitor across VDD and VSS (10 uF should do or anything close to this)
    4) You do have pin 5 connected to your PIC ground?
    5) try another power supply that can be regulated (or 3 AA batteries in series)
    6) Do you have access to an oscilloscope? see what is coming out of PortA.1 and pin 2 on the cable?
    7) Check your hyperterminal settings to make sure you have 300 selected and the parity off
    8) you have been using a crystal like in your sketch?
    report back
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Apr 2007
    Quote Originally Posted by paul borgmeier View Post
    Correct
    Will do again - didn't make a difference last time
    Will do
    Yes
    Will do
    I don't have one unfortunately - an LED flashes like mad though...
    Have checked that many times!
    4MHz with capacitors as drawn
    Apr 2007
    Default Further Investigations Reveal...
    My computer won't talk to a serial modem anymore... and it won't echo its own data from Tx to Rx either...
    That explains it!
    Then a new question pops up... How was the serial JDM2 programmer verifying the PIC's contents? (I know the PIC was being programmed successfully too!)
    Anyway, I'll get my hands on a new set of serial ports tomorrow
    Skimask and Paul, thankyou so much for your help so far! I've learnt alot even though the ideas havn't solved my problem! Thanks again!
    In post 5 I asked about the PC port, and you said that the same thing happened on another computer. ?????
    As far as the programmer software reading back correctly, all I can say is it happens. I have a PICKIT1 that will read back errors if I use the software that microchip supplied, but mplab does not. Both software work. I would guess in this case the "lesser" software does not have something correct in its receiving side, like a checksum miss calc.
    Again, check the signal with a meter. TX will show low (Maybe even a negative value) when idle and will spike anywhere from 2.5 to 25 V+ at transmit. If you have a machine less than 10 years old or using a usb/serial adpt, you will most likely see 2.5 to maybe 6.
    Apr 2007
    I know! I checked it and it was fine, and the other computer behaved the same... I must have stuffed that up! (Not sure how though!)
    Apr 2007
    Talking All Is Well!
    The new serial ports let everything behave as it should!
    I wish I knew the port was dead 2 weeks ago!!!
    Thanks again everyone, very good help
    Tom.
    Last Post: - 8th March 2010, 20:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 16:46
  3. Strange Serout Behaviour
    By bluesmoke in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 04:12
  4. Advice-scrutiny for my serial controller
    Last Post: - 13th December 2008, 17:11
  5. Replies: 11
    Last Post: - 13th July 2005, 19:26
