You show VSS = -5V on your sketch. It should be VSS = 0V
ALso, If you have nothing between your +5.0V power supply and your PIC, then you should measure +5.0V between VDD and VSS on your PIC (not 3.5V).
EDIT: it sounds like a grounding problem just like you suspected
