Strange SerOut Problem
Results 1 to 40 of 40
    Have you checked the PC port or the signal from the cable?
    Apr 2007
    I'm using COM1 to send/receive data to the PIC, and i'm also using COM1 to program the PIC (using only one program at a time of course). So there's nothing wrong with the COM port because it programs the PIC fine.
    I've tried another computer also, with no different results.
    Apr 2007
    I have PORTA.1 connected directly (with a resistor) to the RX pin on the serial port COM1 (pin 2 if I remember correctly) and using Hyperterminal for the time being.
    Do I use 'Driven True' (T300) or 'Driven Inverted' (N300)?
    skimask, you suggested Driven True. Is this right for my setup?
    Thank again.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    If your pic is directly connected to the PC, you need inverted (idle low)
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Apr 2007
    Thanks Paul.
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
  3. Strange Serout Behaviour
    By bluesmoke in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 05:12
  4. Advice-scrutiny for my serial controller
    Last Post: - 13th December 2008, 18:11
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
