PWM Module 18Fxx31
Results 1 to 7 of 7
    Hangover, Germany
    Smile
    I'm working with the 18F2431...
    Forget the PICBASIC PWM-Modules, this device has to be coded "by hand" !
    I'm powering a brushless DC-Motor and I can't see your problem "around 0". Before programming new values to PDC* you have to set a bit and clear it afterwards in order to realy update the timings.
    Yes, there are 3 (or 4) independent PWM-Modules inside !
    Jun 2006
    Default details
    Hi!
    Can you give some details about your project.Also some code will be really helpfull explaining the timings,updation of PWM and use of motion feedback procedures.
  1. 18F2331 Advanced PWM Questions
    By JDM160 in forum mel PIC BASIC Pro
    Last Post: - 24th July 2010, 23:04
  2. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  3. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  4. Using PWM built in Module 16F628
    Last Post: - 9th October 2007, 06:40
  5. pic 18Fxx31 PWM module
    By dirace in forum mel PIC BASIC Pro
    Last Post: - 15th May 2005, 19:51
