can't get serin to work
Results 1 to 14 of 14
    Feb 2005
    Toronto, Canada
    Thanks so much guys!!
    I shall try both lowering the baud rate and using an external 4mhz crystal.
    it makes sense that it would need a correct oscillator and not the internal one, I'm still just working my way up from simple blinking on and off.....
    I have no idea what OSCCAL or OSCTUNE are, but that's what the helpfile and google are for.
    THANKS!!!!!!
    OSCCAL and/or OSCTUNE are some register available on some PIC model which allow you to fine tune the internal OSC.
    But bear in mind that ALL internal OSC will shift depending of temperature, humidity, gas price, wind direction leap year and so on. If your application is not timing critical, they are really useful, unless cross your fingers
  1. serin not work
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 20th March 2007, 11:36
  2. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
  3. Serin with low voltage
    By f_lez in forum General
    Last Post: - 21st August 2006, 12:52
  4. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
