State machine programming
Results 1 to 5 of 5
    tjstevens's Avatar
    tjstevens Guest
    Unhappy State machine programming
    Does any one have a sample of state machine coding for Pic Basic Pro?
    I need to sequence though several machine states (I/O) and run PWM in the background. I'm having trouble with the cycle times not being consistent. I believe that state machine may be the answer. Please HELP.
    Lets say assembler may help... but without seeing what you have now, it's hard to suggest something or know why it doesn't work as expected. Is this a software or hardware related... ??? who know
    If you're using interrupts, that might be one problem source... but...mmm hard to guess.
    Here's a link to finite state machine programming. http://www.emesystems.com/BS2fsm.htm It's based on the BasicStamp but should be close enough to work with PBP.
    /Henrik Olsson.
    Ok... one more thing i didn't knew the right translation.
    Anyways, here's a link i got from Tim Box. That should clear up few thing
    http://protongeeks.com/index.php?opt...d=55&Itemid=29
    tjstevens's Avatar
    tjstevens Guest
    Smile Many Thanks
    I'll check it out. I post to let everyone know how it turns out.
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 04:37
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 17:51
  3. Replies: 6
    Last Post: - 1st February 2008, 04:35
  4. PIC programming algorithm - where is it to find?
    Last Post: - 24th June 2007, 19:31
  5. Programming software for PicAll Hardware
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 16th July 2006, 09:15
